Hi
Just asking if there's any reason why I shouldn't use Ultegra 6700 levers with SRAM Force mechs? I know SRAM only recommend using their levers with their mechs but I can't see any reason why Ultegra with Force mechs would be a problem.
Anyone know any better?
5 comments
IHphoto [117 posts] 3 years ago
I think they have a different cable pull ratio - Most Sram is 1:1 vs 1:2 for Shimano , from memory. So unless you can find a 'shiftmate' adapter (they do ones from Campag to Shim but not sure on Sram) you're best sticking with one make.
glynr36 [637 posts] 3 years ago
Different pull rations on the rear, fronts are compatible though.
AWP [113 posts] 3 years ago
Okay. Thanks for the info.
Agreed - fronts (left levers) are interchangeable, but one buys and uses them as pairs usually  3
