Been wanting to upgrade wheels for a while and a good excuse has just cropped up - hubs on wheels on winter bike have finally given up the ghost, so Fulcrum 4s (these will take a nine speed cassette right?) can come off the summer bike - and I've narrowed it down to these two.
I can get either for pretty much the same money. Fulcrums are marginally more expensive but I can live with that if the premium is justified. The Shimanos, I believe, are fractionally lighter and I've read good things about the ride smoothing out the road surface, which in the UK has got to be a blessing.
I'm a little over 70kgs so that is not really a consideration.
Nice problem to have, but I really don't know which to go with - input would be appreciated...
7 comments
Shred [17 posts] 4 years ago
I like my Fulcrum Racing 1 2-way fit, and I run them tubeless. I've had absolutely no problems with them and they see to roll very well.
I've heard they are stiffer than the Shimano's, but can't compare as I've never had them.
step-hent [727 posts] 4 years ago
I had C24s. I loved them to death - almost literally, as the rims have now almost worn out, one has developed a slight kink at the very top of the brake track (because the rim is almost worn through) and I've relegated them to rollers only. Booooo.
When they were still in service, they were light, zippy, smooth riding and all round brilliant wheels. The hubs are some of the nicest I've ridden - they were ridden through all sorts of crap weather and never serviced (accross two full season's use) and they never skipped a beat. They still roll ridiculously smoothly.
It's worth bearing in mind that one of the reasons they are light, though, is because there isn't much material in the rim. There's plenty of strength (because of the carbon reinforcement) but there's not much room for rim wear. Once the rims wear out, they can technically be replaced by Shimano, but its practically the same cost as buying the wheels again. It's the reason I now only ride handbuilts, and the only reason I wouldn't buy the C24's again - performance wise they were top notch.
If you'd consider handbuilts, the Dura Ace hubs would go very nicely with a Velocity A23 rim, and make a really nice zippy, lightweight, serviceable wheel. Probably on a par with, or cheaper than, the C24s too....
bashthebox [752 posts] 4 years ago
I'd go with similar thinking to step-hent. Get some nice handbuilt wheels - my LBS does a velocity A23 laced to a hub that I forget right now, which come in around the same weight as the c24s but only cost around £450. Wheelsmith make something very similar too. Both should be more solid than the factory wheels, I think, and make you feel all smug and special when someone asks you about your exotic wheels.
manoirdelourde [26 posts] 4 years ago
A friend of mine has 7900 C24's, and has only good things to say about them.
I recently looked at a used set of C35's, and a used set of Racing 1's (couldn't stretch to new for either). The C35's had a problem with one of the hubs, and the Racing 1's needed a new rim. The cost to repair either was prohibitive.
After a bit of research I ended up buying a set of Race 24's from Wheelsmith. They are a very nice set of wheels.
My only (very) slight issues with them are:
1) They look a bit plain compared to the Ksyrium Elites they replaced (I do like the look of Ksyriums with the machined surfaces and the nipples). Unfortunately the Ksyriums are now fitted to Mrs MdL's bike, so I see them most days.
2) They came in slightly over weight (1460g instead of the advertised 1430g, although the 1460g weight included the rim tape), but well within the tolerance stated on the Wheelsmith web site and certainly closer to advertised weight than any of the Mavic wheels I have previously bought.
Last week I took almost a minute off my previous best on the Col des Ares hillclimb course, and several minutes off my previous best on the Col du Tourmalet. Of course my recent interval training and the 300 miles charity ride I did the previous week may have helped improve my times, but the wheels were faultless. I am using 23mm Conti GP4000s, and on the 24mm rims they look huge . . . hopefully improving comfort and reducing rolling resistance.
Thoroughly recommended wheels.
mbrads72 [223 posts] 4 years ago
I can't compare as I only have C24s, but I can certainly vouch for the improvement in comfort. I went from Ksyriums to the C24s and initially stopped a couple of times to check the tyres were still fully up to pressure!
I don't know about longevity as I keep them for best, wearing GP4000S. Aksiums with Gatorskins do training duty and the difference in feel between the two sets is like riding a different bike.
Al'76 [110 posts] 4 years ago
Thanks all; decided to go with the Fulcrums...  36
Gromski [58 posts] 4 years ago
+1 for the Wheelsmiths, although I have the Race23s
