Repair the puncture or throw it away and replace with new?!
21 comments
Shanefutcher [98 posts] 4 years ago
Always new tube
pdows47 [103 posts] 4 years ago
Depends, if the puncture is on the seam, bin it, its much more likely to rupture dramatically (read 'explode') and temporarily deafen you in at least one ear. If its not on the seam fix it, its cheaper in the long term
skitza [94 posts] 4 years ago
little nick about 8mm from the seam , ive repaired and left in the garage to dry before i give it air and put a new one on the bike
jason.timothy.jones [293 posts] 4 years ago
repair, i had a tube with 8 patches, only replaced after the valve went
Tony Farrelly [2919 posts] 4 years ago
I used to like sitting down and repairing a few punctured tubes all in one go very a very satisfying feeling… mind you, that could've been the glue
mrkeith119 [87 posts] 4 years ago
Replace tube while out, fix punctured tube when you get back home, to be used as spare tube next time.
Leviathan [2903 posts] 4 years ago
One shot: repair, Snake bite: bin. I always find with two holes the patch becomes too big and difficult to cover both sides of a flat tyre.
arfa [855 posts] 4 years ago
Used to repair when I got home but now largely replace and bin punctured tyre, especially after bulk purchase of replacements. Having run gatorskins mostly this year I have only had 2 punctures in 6000 miles (cue the gods levelling that one out....)
sm [406 posts] 4 years ago
It's quicker to repair than order a new one online / from local LBS. That said it's dull. I have a pile that need repairing and will one day get to them, honest guv'nor! Save the planet (every little helps) and save yourself a few quid unless as others have noted it's irreparable.
Comrade [218 posts] 4 years ago
Repair and reuse, think of the $avings...mebee I'm just tight!
Colin Peyresourde [1827 posts] 4 years ago
I keep taking the punctured ones home, but I haven't been running through them so quick, so I keep buying new ones to replace them.
Agree with the snake bite and one shot situation too.
If you know kstarr, and sanfranciscocrossfit on youtube, you could always turn the old inner tubes into voodoo floss......
....or a belt.
Super Domestique [1619 posts] 4 years ago
New tube, then a few repairs at once.
chrisl [54 posts] 4 years ago
Definitely repair it, but with sticky patches as they're so much easier. I usually do it there and then since I'm out on my own and in London the cause tends to be easy to find - the large spikey object currently sticking out of your tyre.
I'm getting creative with my old tubes: cable tidy and tiny jersey wallet so far, sweat-proof phone case coming up...
Jaynana [17 posts] 2 years ago
i used to always throw and replace at the first punchure.. not so expensive but seems not helping the world much.. so thinking of changing strategy!
can you recommend the repair kits you use please..
ps - sorry to resurrect an old thread.
vonhelmet [848 posts] 2 years ago
Park Tool do decent self sticking patches.
I use Rema Tip Top patches at home. They've repaired many a tube. You can buy them in little kits, like you'd take out on the bike with you, or you can buy huge sheets of the patches and lots of tubes of glue, depending on how unlucky you're feeling!
levermonkey [681 posts] 2 years ago
If it's wet - replace tube, repair tube later (in the warm & dry) and refit.
If it's dry - repair using Park Tool Pre-Glued Super Patch.[Other brands are available]
Repairing by the roadside using a pre-glued patch is often just as quick as changing the tube and as good as the old-fashioned glue on patches.
Is tube is ripped rather than punctured then cast immediately. There is no upper limit to the number of patches a tube can have but I tend to cast them after I get to five repairs.
crikey [1251 posts] 2 years ago
A tube weighs as much as a puncture outfit, so I take 2 tubes along, and repair 3 or 4 at once on a quiet windy/wet evening at home. When repaired, I take the new tube out and replace it with a repaired one so I know if it goes down over night.
Proper repairs involve a good sanding down of the inner tube around the puncture, then glue allowed to dry, then patch...
Red Rumble [7 posts] 2 years ago
As a kid I always liked the feeling of independence that repairing a puncture brings. Never grew out of it. Old enough now to reach for a new tube when riding in the murk though...
Redvee [376 posts] 2 years ago
I recently purchased some new tubes but still repaired the few punctured ones I had. Like a few here, I bulk repair tubes, 6 or so at a time and dunk them in the bath, to make sure they're airtight.
wellcoordinated [206 posts] 2 years ago
Puncture - what's a puncture. Stan's no tubes, it the thinking mans choice.  3
fukawitribe [2086 posts] 2 years ago
I'd recommend the Park Tool Super Patches maybe as a useful extra or even potentially as a replacement for one of the tubes - they're cheap, the packet is tiny and as close to weighing nothing as makes no difference. The adhesion is superb and consistent, even with a less than perfect surface to stick to. There's not the same stretch as a rubber repair but in reality it's not noticeable - you could even stretch the puncture area a tad with your fingers if you wanted to get it bang on, but i've never had one let go or cause the tube around it to degrade/tear.
I tend to carry a single tube and the patches - first puncture gets new tube, patches cater for anything else (or when I forgot to replace the spare tube - d'oh).
