I've just got a new PG1070 Sram force cassette in the post. I've put it on my Shimano R501 wheel (which I just took an Apex cassette off), but there seems to be a bit of back & forth rotational play, maybe a mm or so. It feels as if the freehub teeth/grooves aren't wide enough.
I've never had a problem fitting Sram cassettes before, am I missing something? I know the old OG cassettes had some compatibility issues a few years back.
The freehub was fine (only about 500 miles in it since new) with the old cassette.
Any help IDing the problem would be great.
9 comments
Colin Lynch [15 posts] 4 years ago
You're missing a spacer that goes between the biggest sprocket and the spokes (it goes on first, before the cassette).
It's a 1mm spacer that you need when installing SRAM cassettes on some Shimano wheels. If it's not included, any bike shop should have one.
Mr Jono [102 posts] 4 years ago
Thanks Colin. Is that sold separately or should it have come with the cassette? There was nothing else in the box
therevokid [1020 posts] 4 years ago
hhmmmm... never had to use the 1mm spacer on my SRAM cassettes.
Thought that was only for Shimano 10 speed on to 8/9/10 freehubs ????
I have a pg1070 on a R501 and with the lock ring off that too "rotates" very
slightly on the splines ....
Pauldmorgan [234 posts] 4 years ago
I have Sram cassettes on most of my bikes / wheels - no spacer in-between the big cog and the hub (unlike with Shimano cassettes).
My son has a Shimano cassette - this does have a spacer. He once installed it with the spacer between the locking and the cassette, not a mistake he'll make again...
That's interesting to hear. I didn't put the lockring on as I thought something was wrong. I'll give that a go tonight and see if there's still any play.
Thanks
Tightened the lockring - no play. Seems silly now!
Spangly Shiny [187 posts] 4 years ago
I needed the 1mm spacer on a Mavic Ksyrium Elite but not on a Shimano DA C24.
