I've recently upgraded to a full pannier rack to do some touring on, but it needs a decent light. I've put one o the lower section but could do with one to replace the reflector. Does anyone have any suggestions? Thanks in advance!
5 comments
drfabulous0 [408 posts] 3 years ago
You can use any light if you just make or buy an adaptor.
Al__S [1170 posts] 3 years ago
Cateye do a mount that screws to two-hole rack reflector mounts that takes their standard rear lights.
babybat [27 posts] 3 years ago
I've got a PDW Radbot 1000 light which comes with a mount that you can attach to the back of the pannier rack. They supply screws but I've found cable ties work better. Evans also sell replacement mounts so you can swap the light between multiple bikes if you want. Have been using it for a year so far with no problems.
armb [107 posts] 3 years ago
I had a Cateye AU100 held on with a single screw, with slightly modified extra reflectors either side of it. But (after years of use), it's now lost the main part of the light (black back still screwed to bracket, bit with batteries and actual light missing.
I'm tempted by one of these to replace it:
http://www.bumm.de/produkte/akku-ruecklicht/toplight-flat-s.html
(I have the "Toplight Flat" (non-S, without the Linetec) on another bike, and it's okay, but not great. So I'll be interested to see other recommendations too.)
PJ McNally [591 posts] 3 years ago
Smart / Phaart lights also do a bracket that fits to the rack mounting area.
But you still need a reflector, somewhere!
