12 comments
just buy a zefal swan rear guard they r fine fits on to ur seatpost
here's wot ya need ...
http://www.sjscycles.co.uk/sks-stainless-steel-rear-mudguard-chainstay-b...
Boom!
Thank you.
That's the chainstay bridge, not the seatstay bridge.
Oh, and some mudguard sets, such as SKS chromoplastics, come with a metal bracket that can clip over the chainstay bridge if it isn't drilled. You could use one of those. (Local bike shop may have a surplus one if you don't.)
It is indeed a 'rivnut', knowing what it's called certainly makes it a lot easier!
For those unsure from my OP it's be bridge behind the bottom bracket, not the bridge that the brake caliper is attached to.
Simple solution will be a nut & bolt, slighty more elegant solution will be to have a new rivnut installed.
Bike model and pictures might help identify / solve your problem.
If it is a rivnut I can see the issue, and have had the same with bottle cage nuts.
You are left with very little to grip to drill out the old one, once you have it out you will need a new nut and a tool to insert it.
For the cost of the tool it is generally cheaper finding a bike shop that can do it for you.
Do you mean a threaded insert that sits in a hole in the bridge between seatstays? Similar to the one that a bottle cage would attach to on the downtube? If so, these are called 'rivnuts', I believe. i.e., half-rivet, half-nut.
put a longer bolt through, and a nut and washer on the other end, maybe?
I'm also struggling to picture what you are explaining.
For bikes that dont have mounting points the general solution is to use p-clips. It'll cost a couple of quid and holds racks and guards very securely. Mighr help fix your problem.
Can you not just use a plastic bolt and nut?
I don't understand.
Is this a carbon frame?
Don't you have a brake on the seatstay bridge?
