Good Afternoon,
I am wondering if I could have some help. I am an amateur cyclist, riding a Cannondale Caad 8 with DT Swiss Wheelset. I dont have much experience with different tyres. However my Michelins currently are like wearing ice skates in the wet.
I need a set of budget tyres, that are well protected and have some resemblance of grip.
Any assistance would be grately received.
Regards
29 comments
arfa [855 posts] 4 years ago
GP 4000's on sale at wiggle for next 2 days - £55
gthornton101 [158 posts] 4 years ago
+1 the Continental GP4000s.
700c [1167 posts] 4 years ago
Budget tyres?! Not continental then..(although I've heard they're good). I like Michelins but agree with you, grip in wet is poor.
My winter / poor weather favourites are bontrager hard case race light 25c.
If your budget is actually big enough to consider continental GP 4000 then why not go to the next level with Vittoria open corsa 320tpi?
ilovemytinbred [161 posts] 4 years ago
The vittoria is not a budget tyre, even if you can get them cheap the wear rate is damn quick making them £££ per mile. They are not that puncture proof either. - Really nice rubber though.
The Michelin pro 4 endurance are pretty good and I found them for £20 each a while ago.
The GP4000s are a great tyre, I dont think they are amazing at anything but pretty good for everything. Wear slightly below average I reckon.
Indeed, nobody said Vittoria was a budget tyre, but if folks are suggesting this Conti then personally Vittoria would be my preference.
CharityChainAstley [6 posts] 4 years ago
Thanks for all the suggestions, I think for now I may look at something along the lines of the Michelin Pro 4.
Would the Schwalbe tyres be any good?
Again thanks for your inputs.
Low Speed Wobble [156 posts] 4 years ago
I'm running both the Vittoria Open Corsa and GP4000S on a couple of bikes. The Vittorias ride nicely, but wear rate is horrific. Also appear vulnerable to cuts (although I haven't had a puncture yet). I wouldn't advocate them for all rides. As @ilovemytinbred says the GP4000S are a good all-rounders, and unlike him I do feel their wear rate is very acceptable. Given the time of year you might be well advised to think about 25mm Gatorskins though.
(I'm not sure what you mean by 'budget', but searching for a cheap tyre is a false economy. Simply, they'll ruin every ride in one way or another. I think all the tyres named above give great value for money - which is perhaps a more important measure of their worth).
I found Michelins more vulnerable to cuts than Vittoria, however I was on the pro 3 SC, not the newer pro 4, or the endurance model. Amazing rolling resistance tho.
I just replaced my rear Vittoria after 1400 miles, front still looks pretty good after same mileage. I don't think that's horrendous, but depends on your definition I suppose.
As LSW says, budget tyres are false economy, all of these mentioned are good tyres for what they do, wear rate and performance varies according to purpose
Simon E [3124 posts] 4 years ago
Around £10 each:
Schwalbe Blizzard Sport. Quite light, I have a folding pair on for over 12 months that have been surprisingly good.
Alternatives I have heard good things about include Vittoria Rubino rigid (wire bead) and Zaffiro, but I've not tried them.
Under £20:
Vittoria Rubino Pro III
Bontrager Race Lite Hardcase
Michelin Lithion II
Above £20:
Schwalbe Durano (but not variants e.g. Skid, Plus)
Michelin Pro 4 Endurance
Continental GP 4 Season
There are others but these 3 are consistently top rated allround/all-year tyres.
PJ McNally [591 posts] 4 years ago
Tyres aren't the best place to cut corners. Good tyres might cost 50% more but if they flat even 10% less i'd say they're worth it!
(and some tyres flat orders of magnitude less than others).
That said - if i want a cheaper tyre i go with Vittoria Rubinos. I'm also quite impressed with Giant's own-brand P-R3 tyres at the moment - which are very very cheap at Rutland Cycling right now!
lazyusername [105 posts] 4 years ago
Vittoria rubino pro's get my vote as a good all round stock tyre. Seem to be a good compromise between being able to go round corners/puncture resistance/ease of fitting and are relatively cheap and easily available in a 25.
TheHatter [770 posts] 4 years ago
Scwalbe Durano's are pretty good - wear well but again not really budget.
therevokid [1015 posts] 4 years ago
another +1 for rubino pro's ... specially the 150 tpi
version and they're dirt cheap  1
dunnoh [214 posts] 4 years ago
I use Vittoria Paves. They arnt budget but I have managed to avoid several high speed crashes because of them and the great grip they have in the wet. In a way they have saved me money!
joemmo [1164 posts] 4 years ago
A warning - I just got some wheels built up with dt rims and could not get my continental GP tyres on them without some swearing and serious levering - and my thumb based tyre fitting technique is pretty good. The rims just seem to be a couple of mm bigger than mavics and it makes a big difference.
The thought of trying to get a tyre off and on at the roadside was not attractive so I've just got a pair of Schwalbe duranos on recommendation. They popped on easily by hand and so far so good.
Wow, I have been riding for about 12 months and organised a couple of events, as supporting charities is very important to me.
One thing I don't think I anticipated is the extent of tyre cost, although I wouldn't put cheap tyres on my car, for some reason I am trying to scrimp and scrape on my bike.
Stuck which ones to get now  40
Could I also ask, can I simply just change for a 700 x25c rather than 23 profile? What impact does this have?
Thanks again
FMOAB [289 posts] 4 years ago
25mm tyres have greater volume and in my experience provide greater comfort on long runs. Unless the clearances on your frame or brakes is really tight you should have no problems. Recent research also seems to say that 25mm provides lower rolling resistence than 23 mm and the pro peleton seems to agree.
mike the bike [970 posts] 4 years ago
Worth a try for an inexpensive tyre, as mentioned by Simon E, is the Schwalbe Blizzard.
It's one of cycling's unsung heroes, combining reasonable flat protection with respectable grip and longevity. Probably the best value around if you are working to a tight budget.
A step up in performance is the Michelin Lithion 2. It's rated as a training tyre but actually performs well enough to satisfy most people. It will cost more but always seems to be on offer somewhere.
I, along with quite a few riders I know, have switched completely to 25mm rubber. It seems a little more comfortable and doesn't roll any slower so what's not to like?
Best of luck.
joeegg [64 posts] 4 years ago
I've been using some Michelin Lithion 2's and found them perfectly good . Not one puncture and far better than budget Schwalbes.Got them in 25's for around £12 each from Ribble.
Thanks for everyones interest...I will buy some Michelin Lithion 2's as a number of you have suggested. I will also change for the 25's hoping the clearance is enough.
I am on a tight ish budget at present, as the wheels cost me.
The ride rides beautifully well, and I am really happy with it, will post a photo later tonight on the my bike photo post.
Any one around Manchester Area up for rides out give me a shout. Also I am congregating people for a manchester to blackpool on the 12th October should anyone fancy a trip out?
Andrew
Ps I will save up for some more elaborate tyres and im sure I will be back on to you in the future for other assistance, this forum is a great source of knowledge and a wealth of experience. Thanks
I suggest you post a new topic about this in case people who might join you don't check back / weren't interested. Hope you get some company.
60kg lean keen ... [75 posts] 4 years ago
I use Michelin Lithion 2's on my Triban 3 for £22 ish a pair whats not to like, roll well sick well wet or dry and tough enough to last(only the odd nick, filled with Supper glue) happy
Thanks Simon, done awaiting authorisation
daddyELVIS [654 posts] 4 years ago
My advice - don't skimp on tyres! The reasons why are logical. £50 or so for a pair of quality tyres is money well spent. BTW, Conti 4 Seasons gets my vote, especially now that winter is just around the corner. They are light enough to run all year round, grip is great in all weather, they roll relatively fast, and puncture resistance is up there with the best.
"skimp"? Hmmm. There's not much wrong with my £10 tyres, they do the job perfectly well. Not everyone has £50 to spend on a pair (and expensive tyres often wear faster than cheap ones).
Not that there's anything wrong with spending £50 a time for those who can afford it.
Edit: Spa Cycles have Blizzards for £7.50 rigid and £9.50 folding and even a 25mm version for £12: http://www.spacycles.co.uk/products.php?plid=m2b0s121p0
pants [239 posts] 4 years ago
YOu can get some durano S on ebay for £20 each
mrmo [2096 posts] 4 years ago
In contrast i was using a set of cheap Continentals, and to be honest cornering on wet roads was not fun. They constantly felt like they were sliding around, in contrast i am now using a set of Pro4s and the bike actually rides ok in the wet.
Yes expensive tyres do wear faster, in simplistic terms, soft=grip=high wear rate. Cheap=hard=durable=crap in the rain. pays your money, except your compromises
