Everything listed is plus postage, some of it is quite heavy so be aware! Happy to do deals for more than one item, if you think prices are too high feel free to make an offer.
Light and Motion Stella 120(?)
IMAGE(https://lh4.googleusercontent.com/-fKDn7XBpyNM/Ui35QVZ7SeI/AAAAAAAAAg0/tpdYtE_iOnQ/w983-h553-no/DSC_0156.jpg)
Don't know if this works as I can't find the charger. Might be good for spares if it doesn't, so £10.
2 x pair of SRAM X0 9 speed gripshifters
IMAGE(https://lh6.googleusercontent.com/-0PYu4o8zBkM/Ui35SxNTYMI/AAAAAAAAAg8/m1pOh8Kurhg/w983-h553-no/DSC_0178.jpg)
Great condition and work perfectly. £20 a pair.
Rockshox Upper and Lower Bushings
IMAGE(https://lh3.googleusercontent.com/-Zz6GQdgUnRo/Ui35UUF2v8I/AAAAAAAAAhE/nkU4x_QDQss/w983-h553-no/DSC_0170.jpg)
Never used, brand new in packaging. £16 the pair.
Deore long cage 9 speed
IMAGE(https://lh4.googleusercontent.com/-EbTXnAnsu30/Ui35XNGAgzI/AAAAAAAAAhM/66uRphlFL64/w983-h553-no/DSC_0155.jpg)
Works fine, needs new jockey wheels, £12.50.
Campagnolo 9 speed Veloce rear mech
IMAGE(https://lh3.googleusercontent.com/-nP4DZ04NJig/Ui35daymEfI/AAAAAAAAAhk/T9dY7R2W07M/w983-h553-no/DSC_0159.jpg)
Needs new jockey wheels, dirty but works fine. £12.50.
Old XT 9 speed rear shifter
IMAGE(https://lh5.googleusercontent.com/-XR-8Bp6d_78/Ui35gEGpEzI/AAAAAAAAAhs/I09z2kJXskY/w983-h553-no/DSC_0167.jpg)
Works fine, looks tatty. £10.
British military combat boots
IMAGE(https://lh5.googleusercontent.com/-QYIXB1Kgs7s/Ui35buYD_EI/AAAAAAAAAhc/x_3L1FlL70I/w983-h553-no/DSC_0149.jpg)
IMAGE(https://lh6.googleusercontent.com/-lTlTPVVIQxI/Ui36R0Gji7I/AAAAAAAAAkU/YOXcBTtaOyk/w983-h553-no/DSC_0153.jpg)
Both pairs, super low usage, size 10. £15.
Same as above, but no laces. £12.50.
Avid SD5(?) brake levers
IMAGE(https://lh5.googleusercontent.com/-rty8g8EMo1k/Ui35ifJYaQI/AAAAAAAAAh0/u5gY-lmWf-4/w983-h553-no/DSC_0181.jpg)
Really good condition, £12.50.
Campagnolo 9 speed right hand lever
IMAGE(https://lh5.googleusercontent.com/-EoUMSDterOw/Ui35khNjDsI/AAAAAAAAAh8/SEyOfnIbxjA/w983-h553-no/DSC_0166.jpg)
Works great, left hand lever got trashed. £10.
Shimano XTR Carbon plate E-Type (Direct mount?) front mech
IMAGE(https://lh5.googleusercontent.com/-9Xelp2cLUEA/Ui35nNf1ghI/AAAAAAAAAiE/VW-u0QeNYn8/w983-h553-no/DSC_0160.jpg)
Definitely an E-Type front mech, I've heard a rumour that these can be bodged onto direct mount but can't confirm. £12.50.
SRAM 990 11-34 cassette, red
IMAGE(https://lh6.googleusercontent.com/-RfovlyAOrZI/Ui35p5KzTbI/AAAAAAAAAiM/_ezDN9d4W24/w983-h553-no/DSC_0174.jpg)
Definitely used, but still takes a new chain so got some life left! £10. I can probably find a chain as well for this if required.
SRAM X0 alloy caged rear mech
IMAGE(https://lh6.googleusercontent.com/-QJ5HiUkOn9I/Ui35sUER0gI/AAAAAAAAAiU/6u7WRPGkoxM/w983-h553-no/DSC_0157.jpg)
Bit old, but still working. Needs new jockey wheels though! £15.
Pair of Alligator 160mm rotors
IMAGE(https://lh6.googleusercontent.com/-IuTfnwi8aLo/Ui35xGkScgI/AAAAAAAAAik/pluYfUif-Q4/w983-h553-no/DSC_0163.jpg)
A pair of 160mnm rotors. Decent bit of use but still fine. Lightweight and don't screech! £20.
Probably a 105 or Ultegra 12-27 9 speed cassette
IMAGE(https://lh5.googleusercontent.com/-DOonRAAJh6A/Ui35zicXKTI/AAAAAAAAAis/5k6kITbnYAo/w983-h553-no/DSC_0169.jpg)
Quite a lot of use, but still takes a new chain (just!). £10.
Properly battered 8 Speed Sora shifters
IMAGE(https://lh6.googleusercontent.com/-zP6QyVDZ0ao/Ui351-Zbn8I/AAAAAAAAAi0/ou5ONVHhgOo/w983-h553-no/DSC_0168.jpg)
A LOT of use, but still work fine. 8 Speed and ideal for a hack. £25.
I could find a Tiagra rear and front mech and cassette and chain to go with these for an extra £25.
Shimano rear road bike brake
IMAGE(https://lh5.googleusercontent.com/-v_MMRE40X14/Ui356xj6GaI/AAAAAAAAAjE/98hQyLZ9pxI/w983-h553-no/DSC_0162.jpg)
Not much to say about this. It works. £7.50.
Shimano yellow road cleats
IMAGE(https://lh5.googleusercontent.com/-Jzl4HOPUFFY/Ui359HyNOmI/AAAAAAAAAjM/qL5vX5GrIu4/w983-h553-no/DSC_0180.jpg)
New in packet. £10.
Shimano pressfit road BB
IMAGE(https://lh6.googleusercontent.com/-8fd5G42uUkk/Ui35_Nk-j5I/AAAAAAAAAjU/QYTwaHFVqOs/w983-h553-no/DSC_0182.jpg)
Brand new, never used. £20.
Pair of MTB cable disc calipers, 160mm
IMAGE(https://lh6.googleusercontent.com/-qCnNVx1FzKo/Ui36ELZmxgI/AAAAAAAAAjk/mktCBHOw7ek/w983-h553-no/DSC_0158.jpg)
Made by Zoom, cheap, plenty of pad material. £15.
Shimano Deore hydraulic brakes
IMAGE(https://lh6.googleusercontent.com/-7GGbbDPDyLw/Ui36LZ6FR-I/AAAAAAAAAj8/7VdaOVgF6Co/w983-h553-no/DSC_0175.jpg)
Nice long hoses, work fine. One doesn't have any pads. £50.
Hope gold 160mm floating rotor
IMAGE(https://lh6.googleusercontent.com/--RuxTnFZjKg/Ui36P6MjmKI/AAAAAAAAAkM/DlVmLlWnYao/w983-h553-no/DSC_0165.jpg)
I think this is ok, but not 100% sure so £5.
SRAM X7 rear 9 speed mech
IMAGE(https://lh4.googleusercontent.com/--aHF_VBXYno/Ui36VvqijxI/AAAAAAAAAkk/ATkFYMlftoI/w983-h553-no/DSC_0161.jpg)
This is properly shit. Probably fine for a pub hack though. £3.
Superstar 1x chain device, seat tube mounted
IMAGE(https://lh4.googleusercontent.com/-6deQpouznDU/Ui36afMXXOI/AAAAAAAAAk0/L48d_SyGSNY/w983-h553-no/DSC_0179.jpg)
Works fine, usual issues as documented elsewhere - needs Loctite. £10.
Assos F1 Mille Long leg bibshorts XL
IMAGE(https://lh4.googleusercontent.com/-6YIv2t_evms/Ui3_DVRPKXI/AAAAAAAAAlI/6je171bgzII/w983-h553-no/DSC_0184.jpg)
IMAGE(https://lh5.googleusercontent.com/-hBAfQXgFjY0/Ui3_FqSvCDI/AAAAAAAAAlQ/qHB0S5vjPic/w983-h553-no/DSC_0183.jpg)
IMAGE(https://lh5.googleusercontent.com/-x1u_AOqxzug/Ui3_HVjMDiI/AAAAAAAAAlY/tCWzK3KoOaw/w983-h553-no/DSC_0185.jpg)
Long leg Assos shorts in XL. These were a warranty replacement and are too big for me now I've lost weight! They are absolutely brand spanking new, in box, with tags and all. I think a 20% discount is fair considering you will get a full warranty and all, so £150.
