Just had a yearly service done on my boardman road team carbo, first 150miles were great, now the drivetrain is so loud, like a horrible scrape type sound in the small cog, granny gears when climbing hills, I've uploaded a video to YouTube, any suggestions what could be causing it would be appreciated
http://youtu.be/5rm2tbOT_80
6 comments
tonyhogg [47 posts] 4 years ago
Halfords have attempted to tighten some cables back in that we're replaced after its yearly service but this has not stopped the noise
dunnoh [214 posts] 4 years ago
Sounds like the chain rubbing on the front mech.
Any suggestions please?
The chain doesn't not appear to be rubbing anywhere, I'm not cross chaining, only time I get minor chain rub is going flat out down a big hill but a can trim this out.
RobeH [33 posts] 4 years ago
sounds like your chain wants to go up a cog or down on the cassette,either a screw adjustment or adjust the cable tension should do the trick.
Simon E [3128 posts] 4 years ago
Was the rear gear cable replaced? Most likely is poorly adjusted rear shifting.
Either way, take it back and if they can't fix it then take it to a proper bicycle shop.
I know you say its not rubbing but have you checked your BB. If its loose the chainset may wobble a bit and rub on the front mech under load.
