5 comments
Bike now booked in a LBS to get them to remove sheared bolt, I not confident about drilling it out without causing damage, will get them to fit the mudguards at same time
I've done the exact same thing with my rear SKS guard. Tried sawing a cross head into it but it's jammed tight. Plan is to drill it out but if there's enough showing through on the other side then it may be possible to grip it with pliers and twist it out. And then heavily grease the new bolts...
I'll let you know how I get on with the drill.
Extractor screw should work but tricky with such a small bolt. Could try drilling out from rear of guard eye -- drilling imparts a lot of torque, so there's a good chance it will unscrew. PlusGas first, of course. Otherwise, get a framebuilder to do it.
Just wondered how you got on removing the bolt? I have just done the same thing Sheared bolt is not causing any issues and bike is easily still rideable but as I live in North of Scotland mudguards are essential for the next 5 months or so...
It's called 'helicoiling' and any competent engineering firm should be able to do that for you.
It might also be possible to remove the old bolt stub using an extractor screw which is basically a left-handed screw which you screw into a pilot hole in the end of the bolt. As you tighten the screw up in will/should unscrew the bolt.
