After flicking through the internet I spotted planet x carbon tubulars for £370. Currently use Mavc Kysirium Elite, but I am tempted as I would like a bit of extra speed on the flat in fast group rides.
Interested in peoples comments if they have the wheels. Also as I have never used tubulars I wondered how easy they are to live with for speedy dry rides. They seem really light, but are tubulars too impractical for non racers.
Your experiences on either area would be appreciated.
13 comments
gazer117 [26 posts] 5 years ago
Too much hassle for non racing. The gains are noticable, but I use my pair of PX tubs strictly for racing only. There too much of a pain if you get a puncture as I've had only mixed success with the sealant.
Tjuice [257 posts] 5 years ago
I bought a set of PX R50 carbon tubulars at the start of last season for my summer bike. Rode them with gatorskins right through last summer / autumn before switching to the winter bike. Am back riding on them now that the worst of the winter seems to be over.
They are super wheels - seriously light and fast. Couldn't be happier! I have not yet had any punctures, so cannot comment on hassle, but I do carry a bottle of sealant, a spare pre-glued tubular tyre and a roll of tub tape with me (bit belt and braces, but there you go).
greg43 [8 posts] 5 years ago
Thanks very much for your feedback. I use gatorskin clincher tyres on my wet weather/winter bike. I was looking tubular tyres and they seem to be narrower than normal clincher tyres (less than 23mm). Is this normal and do you run 22mm tyres on your px wheels.
Thanks in advance for your information
Sprinter Gatorskins on my PX wheels are indeed 22mm, so yes, would appear narrower than the 23mm I run on my clincher wheels.
However (and this is actually quite important), tubulars generally roll better than equivalent width clinchers and are more comfortable (despite higher pressures). I run mine somewhere around 100-120psi and they are super comfortable - better than any other tyre/wheel combination I own.
That said, you can also get 25mm gatorskins.
I will admit that gluing the tubs initially was a complex procedure to do right (despite a lot of research first) and it took a number of days to go from having bought the tyres to having them mounted on the wheels! But having learned a few tricks, I'll do it quicker next time...
700c [1250 posts] 5 years ago
No experience with planet X, but you see lots of them about, especially on time trials
Re tubular tyres -.don't be afraid, about the fitting issue. If you are particularly prone to punctures, ie one a week, then you might want to stick to clinchers.
Otherwise, factor in the likelihood of occurrence and the extra hassle of repairing, the benefits outweigh the risks,.IME.
On most rides I just carry sealant in a canister. On really long rides I also take a thin, light spare tyre plus two cans of sealant and pump. If I get through all this then the Gods surely have it in for me and I would struggle no matter the tyre choice!
@700c, what are your recommendations on sealant?
I have a bottle of Tufo Extreme that I have never had to use, so I have no idea how well it works.
arrieredupeleton [585 posts] 5 years ago
Hmmm. I'm also a bit tubular curious. However, the carbon jobbies are normally heavier than the alu equivalent (notwithstand the PX ones) and when you start factoring in the weight of the sealand can, spare tyre (!) and tub tape, they would need to be a totally amazing ride.
I'm not sure I wouldn't just stress all ride long. Fair enough the pros tend to ride on decent roads with support. Such luxuries don't often/ever exist for us mere mortals. I can see the benefit for TTing but for a century ride for example, I'm not so sure.
Convince me it's worth the hassle.
I have Vittoria pit stop and, like you, have never had to use it, so I can't really answer that one. Guess we'll find out if and when a puncture happens..
I reckon I've done about 1000 miles so far on tubs, and stopped stressing a little while ago.
I'm minimizing the risks by using tubs in good weather, my clinchers come out again for winter, when I'm more likely to puncture..
blablablacksheep20 [41 posts] 5 years ago
Very interested in this too, have same wheels as topic poster.
I'm thinking about using them purely for TT races and triathlons.
What is best 82mm ?or 50mm?(basically is 50mm too shallow to see any gains compared to elites)
Good investment? (Will be buying TT bike later this year but it comes with MA Vic cosmic not deeps as standard so these be for it too)
1180g 46mm deep wheels!
@ Babablacksheep, RE use for tri and TT exclusively - yes 50mm makes a difference, but if you're only going to get one set - and using for this purpose alone, you should go deeper.
The reason I've gone for 46mm depth is because they are all round wheels for summer, and I like to go up hills!
Update: decided against them now.
Speaking to some good cyclists (mate rides crit 2) and reading around, deep section wheels are not going to give me any real noticeable gain even at high speeds compared to aero helmet and a decent bike fit.
Only reason mate uses them is they give him a few secs advantage but the cost for this is crazy compared to aero helmet ect.
So I'm holding off until I have helmet and bike fit then maybe ok consider them.... Also elites are awesome all rounders.
I was thinking more about the hassle of tubeless to be honest.
I agree with bbbs's mate, pointy helmet, bike fit, skinsuit and overshoes all offer better gains that aero wheels for much less. You won't look cool though and ultimately we all like to look cool.
Each to his own, of course.
The problem with certain aero improvements, as people will know: the helmets look odd and are impractical for everyday use/ hot and skinsuits also look a bit weird in normal use.
Re price, actually £370 for planet X 50 mm tubulars does not sound crazy at all compared to the cost of a aero helmet (£100- £300), and skinsuit (similar?), and anyway, is there any proof that these give better performance gains than deep section wheels?
Personally I find the improvements over shallow rims to be significant for me. It's also worth re-iterating that tubulars give you access to some seriously light carbon wheels currently on the market - so not just beneficial for the aero- obsessed.
Agreed that bike fit and position must be optimal before considering any of this, that's a given.
PS update on the vittoria pit stop sealant: Used it last night on a mate's clincher tyre which had punctured whilst re-fitting onto the rim - (laziness on our part as his tyres are were a bugger to fit back on) - it did not work at all on this type of flat. (which admittedly you wouldn't get with tubular) - so jury's still out for me on sealant canisters.
