I'd like to purchase a new road bike, a battaglin s11 sora and I'd like to make sure I pick the right size for me.
I've taken all the measures requested by competitive cyclist fit calculator and this is the result
IMAGE(http://img14.imageshack.us/img14/6929/competitivecyclist.jpg)
IMAGE(http://img694.imageshack.us/img694/6775/measurementsw.jpg)
what do you think ?
here it is the geometry of the frame
IMAGE(http://imageshack.us/a/img20/9323/geometriaz.jpg)
IMAGE(http://imageshack.us/a/img708/9071/geometria2.jpg)
Thank you very much for your help
5 comments
ricolek [40 posts] 5 years ago
I'd probably go with M, from the measurements I'm guessing you're somewhere in the 55-56 bike size range. Also if I couldn't find the right size, I'd rather go with a bike a bit too small rather than one bit too large.
tradescant [16 posts] 5 years ago
It looks as though you have long legs for your height, so will need to ensure you don't end up with a top tube that's too long. I think if you go for Large you will end up having to get a short stem.
jengy [72 posts] 5 years ago
The most important measurement to get right is top tube - B, so around 540 in your 1st 2 fits, right between S and M
Seat tube can always be adjusted with seat post height
If you are 178 tall I'd go with M, esp as head tube D is pretty short on the S
I'd try some out with a similar top tube in a shop to check if poss to check reach
For the same as Eddy fit 2 you'd need a 90-100mm stem
vorsprung [283 posts] 5 years ago
That isn't my kind of bike, the head tube is too short  1
Or to put it another way, the top tube is too long
evroniano [2 posts] 5 years ago
it turns out the measures of B and C are inverted, as a result for the M the B is 535 mm while the C is 550 mm, for the L the B is 560 mm while the C is 575 mm
I've just spoken with battaglin customer service
