suncream and the like
by snappyandrew   April 24, 2013
I only started seriously cycling last august so am getting used to that big yellow thing in the sky that I've not really had to deal with before.
I went out yesterday for a long ride and now I have tan lines and a burnt neck. What do you lot do in the summer to stop getting burnt?
Any advice gratefully received
4 user comments
Oldest firstNewest firstBest rated
Get a decent sports orientated sun-cream, I use piz-buin (or however you spell it) mountain range as I generally have loads left from snowboarding - seems to work a treat and last long enough for a decent ride without re-applying.
If you are really worried you can buy P50 from most supermarkets and that will definitely protect you in even the hottest day.
Tan lines should be embraced Cool cremating yourself perhaps not so much.
posted by andycoventry [120 posts]
24th April 2013 - 12:08
I burn quite easily and last summer I started using Riemann P20, which works well. You only need to apply it once a day and does wash off if you sweat.
If the sun is very strong I wear a jersey or t-shirt with a higher collar to protect my neck. Also, I first started wearing cycling gloves due to getting sunburnt hands.
posted by NeilG83 [256 posts]
24th April 2013 - 12:27
+1 for P20. it's not cheap, but it's the best i've tried. best to apply it 30 minutes before you go out, but it's once for the day and you're done.
Dave Atkinson's picture
posted by Dave Atkinson [7473 posts]
24th April 2013 - 12:30
I use banana boat, by the boatload!
I'm riding the 2013 Giro d'Italia for charity! Check it out and follow my progress live at www.tourletour.com
Tour Le Tour's picture
posted by Tour Le Tour [91 posts]
24th April 2013 - 19:26
