I have a pair of 'old' Mavic rims that measure about 21mm across the rim. I have a pair of 23mm tyres fitted that I want to replace with something wider for a bit more air volume when I do Nightrider.
I was thinking of going to 25mm but should I be OK if I go up to 28mm?
I have plenty of space around the forks and seat stays and there is ample clearance inside the brakes which are Campagnolo Mirage.
1 comments
arrieredupeleton [585 posts] 4 years ago
28's should be OK provided your frame can take them.
