1 comments
If you are competent at servicing your own bike it's a doddle. The only tricky bits are putting headsets in and putting handlebar tape on. If the frame has an integrated or semi integrated headset then the only tricky bit is bar tape.
If the frame has a none integrated headset then it is probably easiest to get the lbs to fit it (requires specialist tools which aren't cost effective unless you are fitting lots of headsets regularly).
Bar tape - lots of videos on youtube if you aren't confident. Have a dry run before removing the sticky backing.
Cutting steerers down is pretty easy, if you aren't very good at cutting straight lines you'll need a steerer cutting guide (not too expensive).
Brakes - pretty easy to set up, even easier if you have a Tackx brake setting gadget.
Cables - measure twice and cut long, then trim to fit.
