Hey everyone,
I've got some lights from Revolution, but having difficultly mounting the front one. The bars have an oversize centre section (which is covered by the stem clamp), then tapers over the course of maybe two inches where it meets the bar tape.
I can't mount it on the taper because it won't sit securely, the bar tape is too thick for it to sit over that, and the clamp cannot be turned 90 degree, so it can't go on the stem.
Is it possible to buy an internally-tapered shim that will give the handlebar section a uniform thickness? Any other solution?
Cheers.
5 comments
ubercurmudgeon [169 posts] 5 years ago
Buy 26mm diameter handlebars and stem. That will give you a good couple of centimetres on each side of the stem of straight tube for mounting whatever you like. You'll probably also find it transmits less road vibration and is quite possibly lighter than your current setup. Less stiff, of course, but unless you are either a professional or a gorilla, I doubt it'll affect your performance and/or enjoyment. Why manufacturers fit oversize bars on anything but out-and-out racing machines I will never understand.
Any form of extended mount will vibrate or fall off. They aren't designed for lights, only cycle computers
cidermart [517 posts] 5 years ago
Municipal Waste [256 posts] 5 years ago
What bars are they?!
notfastenough [3729 posts] 5 years ago
Thanks for the replies, suppose they're all a bit of a bodge though really.
@Municipal Waste  4 They are RSP Compact bars that came with the bike. Googling around, they seem to be usually sold that way, rather than aftermarket. I thought they were 42cm c-to-c, but it turns out that, weirdly, they are quoted as 44cm outside-to-outside, and 41.5cm c-to-c.
I'm looking for a new seatpost anyway (current one has teeth for the tilt adjustment and I can't get quite the angle I want), so this just means I'll look for a snazzy matching compact bar and post combo. Any recommendations?
