More agressive position and new wheels. Tips, please!
Hi!
I have had a Cannondale Caadx 105 for a little over a year now. I am very happy with the bike and having a lot of fun.
I have started to get very comfortable on the bike and I want to take my riding a small step further by making my ride a bit more agressive ie. removing the 3 spacers which will lower my position about 1-2cm. Any tips or advice on this? Will I end up with immense back pains or is this quite allright to do?
Second thing is wheels. I am using the stock Maddux rims which I estimate weight about 2.2kg in total or there abouts.
I am torn between Shimano Ultegra or Pro-lite Bracciano. Any opinions?
Thanks for the experience and expertise I don't have
won't give advice on wheels, but i think it is reasonably safe to lower your handlebar little by little, i would suggest going one spacer at a time (i know they are 5mm, but still) and keeping it that way for a couple of weeks before going further. Also try and be realistic about what sort of benefits such modifications give to you, i mean it's all well and good having the handlebars a bit lower, but if this limits the power you can produce in the drops due to hamstring flexibility for example, than it's obviously counter-effective.
I wouldn't worry too much about steching my hamstrings. Right now I think my handlebars are about the same level as my saddle
Do I have to retighten all my cables when I take out spacers?
Nope, but you will extend your reach, so you might find yourself moving forward on the saddle. When I was too low at the front I used to get a stiff neck or shoulder pain after a couple of hours. Try it, one spacer at a time and if it doesn't work, put the spacer back.
Your cables are curved, and the outers take up the slack effectively, so when you move the end, the cable run remains the same, because the sum of the outers and distance between the stops is the same.
I assume you ride on the drops usually? Not much point dropping your front end if you don't
There was a good article on Andy Schleck vs Wiggo a while back comparing TT position, and it made some good points about muscle activation angles. Essentially Andy's muscles would lose power in Wiggo's position, and would actually offset his aero gains and then some, so big changes in position may be beneficial or counter productive. If in doubt get a bike fit, and save up for the wheels later.
As for wheels, depends on budget. The new Ultegras get good reviews. I have RS20, 105, Ksyrium Elites and some other odds and ends, and the Ksyrium Elites are the best to ride. Other brands worth a look are Hope (their wheels are used in the Road Bike Party), American Classic, and Strada have the Velocity and some new rims which make up into wheelsets for the custom build crowd which are in that price range. Not heard anything good or bad about the Pro lites. Pretty much any decent wheel set will come in lighter and will improve your ride enjoyment. Obviously the more you can afford, the lower the rotational weight, the bigger the effect.
nothing much to add about the position thing - give it a go and see how you get on!
I have had a set of the pro-lite braccianos for about 3 months now and I'm really pleased with them. Seem very light, roll really well and I can feel how much stiffer they are then my old wheels (FSA RD. For the money I think they are unbeatable value.
Handlebar height:
Give it a go, but don't necessarily expect benefits to outweigh any initial discomfort on the first day.
But this is only really relevant if you find you are riding on the drops for the majority of your ride. If you ride on the hoods a lot, I would suggest getting used to being in the drops first would make more sense than removing the spacers.
It does take a little while to get used to being a bit lower. When I was getting back into road cycling, I was (a little) fat and not very flexible and it took me quite a while before I was feeling properly comfortable in the drops - I even considered getting compact handlebars to reduce the distance. Now I comfortably ride really deep in the drops. My neck does not thank me on long rides though...
Wheels:
I would recommend looking at Mavic or Fulcrum wheels. You can usually get some good prices, and you won't go far wrong. I had some Fulcrum Racing 5, which I have now put on my winter training bike. They're great wheels for the money. The Mavics are tasty though.
I had a set of Pro Lite Comos which I did not like at all - they were super heavy and felt slow. This has put me off Pro Lites. I also had some handbuilt wheels laced to Ultegra hubs, and I really felt that the Ultegra hubs were a step below the Mavics I was running at the time.
HTH
road.cc on YouTube
5 comments
