I have a Bryton 20 which is okay but I want something that is better & probably with maps. What do people here think about the following?
Garmin Edge 800 GPS Performance Bundle
Mio Cyclo 305HC With Heart Rate and Cadence (UK Maps)
Garmin Edge 500 Red with Premium Heart Rate and Cadence
Okay I know that the Edge 500 hasn't got maps!
27 comments
OllieD [25 posts] 4 years ago
I don't own any of them myself but i've been in the market for one too, the Garmin 800 is very well reviewed!
Gman59c [58 posts] 4 years ago
Edge 500 is good. Although the bits that go with it aren't so good. I have had to replace a HRM strap and a cadence sensor in less than 6 months of use. Garmin aftersales were very good and replaced quickly.
However if I was buying again I think I would look at something else.
CraigS [129 posts] 4 years ago
Edge 500 has a course feature which I've found more than sufficient to navigate with, as long as I plan a route beforehand.
oddbydefault [83 posts] 4 years ago
Edge 500 works like a dream with RideWithGPS.com (free!)
I've used it to navigate Audax and general training rides up to 70miles.
As you plot out the course (you can choose google maps, OScycle etc) a route sheet (with readable cues) is created. You download the GPX file, put it in the relevant folder in the Garmin file tree, and it converts it to a tcx file course.
When you 'do' the course, the Garmin displays distance to finish, distance to next cue (direction change), upcoming elevation profile, a cue sheet WITH ROAD NAMES AND DIRECTIONS (i.e 'Left at Yellow Rd), and distances to each, and a breadcrumb trail (zoomable) with arrows at junctions.
Note - as far as I'm aware, the specific arrows and road names etc can only be done with RideWithGPS.
Overall, I find it very easy to use and anticipate turnings once you get used to it (and set your zoom level to one which you can understand). BUT it becomes infinity harder if roads are very close together and there are lots of turnings.
LeDomestique [34 posts] 4 years ago
I agree the Edge 500 and ridewithgps are a fantastic combination. It's easy to use and much better than the overhyped Strava.
hotweathercyclist [30 posts] 4 years ago
Get the Garmin.
abudhabiChris [691 posts] 4 years ago
Garmin are not in my good books at the moment.
I had what seems to be a fairly common problem (judging by similar issues on their support forum) with the plastic mount on the back of the Edge 500 breaking after around two years.
Out of warranty of course but they replaced it, for 70 quid - however it also cost me 40 quid to send it to them because they have no service in my region and then they put the full retail value on the customs form so it cost another 30 quid to get the thing back. All this because of 50p's worth of plastic.
If that was the end of the story I'd be happy...
Unit came back and won't pick up readings from my speed/cadence sensor on either of my two bikes fitted with them. Both worked perfectly prior to sending it away. I've reset it, followed the Garmin instructions and so on, to no avail.
Contacted Garmin and got "Computer Says No". Apparently it must be the speed/cadence device, not the unit. And if I think otherwise, guess what, I have to pay another 40 quid to send it, and the 30 quid to re-import it, that's assuming they replace it on warranty.
To rub salt into the wound the mucking about with the sensor must have shifted it and the arm got caught in an expensive wheel which now needs a new spoke and ruined a long-planned day of riding.
The only thing that has stopped me getting another unit so far is that Garmin seems to have the advantage in terms of ease of export and compatibility with mapping/logging sites. But I'm looking, and very reluctant to throw more money away on Garmin.
robdaykin (not verified) [368 posts] 4 years ago
why not the Bryton 50T?
therevokid [1017 posts] 4 years ago
use the 800 with openstreet maps and ridewithgps ... pretty
much flawless for recording performance and navigation.
stealfwayne [128 posts] 4 years ago
I'm in the same boat as in lookjng for a mapping GPS - I have read lots and got it down to Grmin 800 or the Mio Cyclo 305HC With Heart Rate and Cadence. Both seem to do the same thing but as a thicko GPX, other softweare required to load or manipulate maps puts me off, Is iot really that difficult....
thanks
chrismday [50 posts] 4 years ago
How does RideWithGPS compare with Garmin Connect? On the face of it they seem to do the same things.
I only use RideWithGPS for mapping. It has an extensive feature set (on par with BikeHike - if not better. And it's a bonus to be able to save routes for future reference (and editing).
Garmin Connect has a map 'courses' bit. It's pretty basic. No cue-sheets, different types of maps, or useful data etc.
sm [406 posts] 4 years ago
Garmin 800. Full maps, easy to navigate. Don't be put off by the occasional moan about problems. Had mine for a couple of years now and never got lost. Use it every week for big 50+ miles down small country roads with no names and even cycled from London to Spain with it. Mapping is easy. Ride with GPS is good although I prefer using google maps and using gmap to gpx to create the gpx file. Best thing I ever bought, after the bike of course!
Littlesox [78 posts] 4 years ago
Garmin Edge 800 (or new model 810)
You will read some negative stuff on the net.
Mine's been faultless, but the "Instruction Manual" that comes with it is rubbish.
The Garmin Connect web-based software is very good.
wjputt [30 posts] 4 years ago
Thanks sm. Still confused by the maps thing! Got HRM & Cadence bundle but no maps. A mistake?
velo pixie [6 posts] 4 years ago
Only thing I would add is related to Bryton 50T - Bought one from Wiggle and couldn't get the mapping feature to work, also couldn't access the mapping on the "back up" cd rom. Brytons technical support have not responded to any of my requests for help and the "Bryton Bridge" web site does not have the required functionality to manage the unit or provide technical help. After a week of buggering around with it Wiggle thankfully agreed to take it back.
I've got an Edge 500 now and really like it.
I got a replacement 50T from Wiggle recently and the map installation process went something along the lines of 'insert micro SD card (supplied), switch on, enter registration code from card' . Maps then worked fine. I did pull the SD card and put the one from the previous unit in, but couldn't activate it with either key which seemed odd, but seeing as the Navteq maps are ok, and I don't strictly need the Open Street Map ones, I didn't worry.
I agree the CD and website are currently useless for managing maps. The issue there is that they recently changed the whole client server software model (to fit my requirements, I suspect, sorry) and map management seems to have become lost in the process. It used to be on the device tab on the website, which is now the local device manager.
Whom did you contact for support? support at brytonsport dot com gets answered usually after a couple of days, often via or cc'd to support_gb at brytoncorp dot net. technical dot bryton at zyro dot co dot uk goes nowhere useful, and in fact Zyro seem the weak point in the whole chain.
Your experiences with Bryton mirror mine with Garmin. When I first bought a 50T I was really pleased at getting responses from support instead of being ignored completely.
Anybody got a MIO cyclo 305HC? this unit is just a bit different from the garmin adn I like the randomizer (3 options) bit. any decent reviews out there? thanks
stealfwayne [128 posts] 3 years ago
OKay so after a whiler I plumped for the MIO 305HC, It works just fine, if you don't want to download the free software release just a few months ago. It won't load on my machine, then after over 10 attempts. success. 'Here we go' i htought. NO! now it freezes my laptop every time I open it. Bloody rubbish. Seriously considering sending it back. ( again it already went back when it froze suddenly' any comments from users very much welcome.
glynr36 [637 posts] 3 years ago
Had my 500, with the hrm and cadence, since they came out (2010 I think) never a single fault with it.
I want to replace it with a new one, as I like new things, but it just keeps going!
Perhaps it's just mine. Think I'll call helpdesk and get them to update for me. Might as well put them to use. Cheers for the comment glynr36.
arfa [857 posts] 3 years ago
+1 for the Garmin 800 and ridewithgps.
Buy it with funds you save not entering sportives and ride the routes without being jeopardized by people taking stupid risks as they think they're racing....
cqexbesd [101 posts] 3 years ago
I'm no expert, certainly not for your part of the world, but most countries don't charge customs or warranty repairs. You might be able to claim your fees back if you produce some documentation.
Perhaps facing the customs department would cost you more than you have already paid of course...
PJ McNally [592 posts] 3 years ago
Which GPS/HRM/Cadence Device?
GPS - android smartphone
HRM - sigma sports HRM watch and strap
Cadence - cheap wired bike computer with cadence
That's how i do it, anyway. Others may have different ideas.
srchar [737 posts] 3 years ago
I have to say that the Garmin Edge 800 is probably the worst gadget I own in terms of quality and value for money, but there's not much competition out there. My £99 smart phone dumps on it for features and build quality. It's even waterproof. It's just a bit hard to mount and the battery won't last much more than 150km.
If anybody knows of an Android-based bike computer, i.e. smartphone functionality (GPS, apps, nice screen) but in a bike-friendly case with a big battery, I'd love to hear about it. If I had any clue about how to build it myself, I would do. Hmm, maybe this is how I make my millions...
So, to the OP, use a phone, mount and external battery until a company makes a product worthy of your £££. The Garmin Edge 800 certainly isn't.
Put your smartphone on airplane mode?
Last time I did a 8 hour ride, this let me record the whole route, with battery to spare.
fustuarium [245 posts] 3 years ago
I got a 505HC and I think the review on here was the best as well as DCRainmaker IIRC (305 is same as 505 but without wireless so 505 reviews are pretty relevant).
Worked very well so far until this weekend. It's not recorded 30 mins of one ride and only first 4 seconds of antoher! Sounds like an issue with V.4 that they're looking at sorting out in next couple of weeks.
