Having made a mistake in choosing a flat barred Cannondale CX4 as my commuting bike last year, I've just finished converting it to dropped bars, and I reckon it improves it no end.
The one thing I feel could still be done to improve it is to fit a set of narrower/slicker tyres once the frosts have cleared. The bike is currently fitted with a set of Bontrager 35mm tyres with a heavy groove (the shop switched the cross style 37mm tyres that came as standard for me). The rims are Maddux 3.0 disc and there's precious little information about them on the web.
How narrow a tyre can rims of this style take? I reckon I could probably fit 32mm kojaks or gator skins, but ideally I'd like to drop this to 28mm tyres if I can. Any thoughts or experiences on doing this would be greatly appreciated.
7 comments
Gkam84 [9111 posts] 4 years ago
Are your wheels on here at all? http://www.maddux-wheels.com/
I see the Cross MX 300 and and the D 300, but nothing about the 3.0 Disc.....They are both 23 wide, so you'd get away with 28 no problem
OR would they be DC 3.0?
http://www.cannondaleexperts.com/Maddux-DC-30-Disc-Rear-Mountain-Bike-Wh...
If they are the DC's then you will get away with 28 no problem, I'd even go as far as 26, something like Michelin City 26 x 1.4
FMOAB [289 posts] 4 years ago
Thanks Gkam, they're the 700c (or 29er as the marketing types would have us call them) version of the DC 3.0. As narrow as 26mm you reckon? Better than I hoped  4
Ok, Having looked at the Madduz site a little further, I would suggest you'd only get away with 28.
They only have one rim listed in 29. The specs are below
Disc X 320(Disc only) 29" 622 x 17 32 H
http://www.maddux-wheels.com/rims4.html
Someone will come along in the morning with more advice I hope  4
bigant [43 posts] 4 years ago
Take tyre off, use ruler to measure inner width of the rim? I reckon 23mm or less would be fine for 28 mm tyres.
robdaykin (not verified) [368 posts] 4 years ago
http://sheldonbrown.com/tire-sizing.html
and
http://www.schwalbe.co.uk/_webedit/uploaded-files/All%20Files/Technical%...
are good references
Cannondale site shows they are DC3.0, but maddux don't list them (grrrr). Could be anything between 16 and 20mm ID if you take in the 700c rims in the trekking list too.
giff77 [1291 posts] 4 years ago
Was going to suggest sheldon brown as well. Everything is dependant on the inner rim width.
Thanks for the responses, you've educated me about another area that was previously a mystery to me.
