Shimano 105 chain replacement?
mckechan, February 14, 2013
Hi,
I have 105 chain and it is beginning to stretch. If I look online for 105 chains, there are multiple choices.
Does it matter, which one I get?
Thanks
If it's 10 speed get a 10 speed shimano compatible chain.
Chain Reaction have one cheapish (£13).
SammyG's picture
posted by SammyG [215 posts] 14th February 2013 - 14:36
The 5701 is to fit a double chainset only and has to be fitted in the correct direction. The 5600 will do a double or triple. You don't have to use a Shimano chain, you could use KMC which has the benefit of a reuseable magic link for easy fitting, removal and cleaning or any other Shimano compatible 10 speed chain. The 5600 is very durable according to the Tour Magazine group test at the end of 2011.
Ah! Condor
posted by Bedfordshire Clanger [209 posts] 14th February 2013 - 14:41
SRAM chains are also shimano compatible and i've always found them excellent as an alternative to shimano, usually some good deals to be had online for one. As SammyG said just make sure you get the 10 speed or 9 speed specific one to suit your setup.
If your existing chain has stretched significantly you might find that it's worn the teeth on cassette / chainrings and when you fit a brand new chain it skips/jumps on the worn sprockets/rings. Depends whether you've caught the chain wear in time.
posted by falls offlots [77 posts] 14th February 2013 - 14:52
There are only two brands of chain I would ever buy again
SRAM or KMC
So whatever speed your chain is, just search google
For example, its a 9 speed. Then just put in 9 speed SRAM chain
Gkam84's picture
posted by Gkam84 [6458 posts] 14th February 2013 - 15:04
Oh and when you trim your new chain lay out your two chains next to eachother like so:
And then trim the new chain to match the old chain -1 link to account for "stretchage" !
SammyG's picture
posted by SammyG [215 posts] 14th February 2013 - 15:11
Wear not stretch
Smile
posted by Benway [43 posts] 14th February 2013 - 15:07
Soz ben I've put it in quotation marks to indicate that the stretch is not a literal stretch.
SammyG's picture
posted by SammyG [215 posts] 14th February 2013 - 15:12
Personal choice here but works for me cheapest SRAM chain I can find on e bay anf change it every 3 months
posted by crash144019 [33 posts] 14th February 2013 - 15:45
KMC X10 are frequently cited as reliable 10-speed chains (same for X9-93 in 9 speed).
Don't lay the new chain beside the old one, you should always count the links.
Simon E's picture
posted by Simon E [1305 posts] 14th February 2013 - 17:53
Seconded on both accounts. Yes it takes longer but it's right.
cidermart's picture
posted by cidermart [282 posts] 14th February 2013 - 18:00
thirded Smile
still on the 3rd switch-back of Bwlch !
posted by therevokid [442 posts] 15th February 2013 - 12:10
Thanks guys!
posted by mckechan [72 posts] 16th February 2013 - 19:43
