Hello there folks,
I'm normally the one that's giving others advice, so if you all want to chip in, fire away.
So the trike came with a triple and its a 30/39/52 but I need some more range, its a 9/32 10 speed on the rear, but on the flat I'm spinning out the 52/9
So I'm looking at replacing a couple of the rings, maybe set it up as a 30/42/55 but having trouble finding the rings to go with my crankset.
Its a SRAM Truvativ Elita, here's the link to the "manual"
http://cdn.sram.com/cdn/farfuture/EHj107okLLfBSPXS9vasz1e3rQc-URzFQkv6s8...
So what am I going to do?
10 comments
spongebob [277 posts] 4 years ago
don't be mental if you have 20" wheels and can get to 110 rpm average you will be going 41.2 mph
Gkam84 [9098 posts] 4 years ago
Even with over 12 foot of chain?
Normal calculations do not work with recumbents
Ah sorry 37.796 @ 110rpm on a recumbent
How are you getting that figure? I'm spinning through the 52/9 around 30mph if I'm lucky.
I'm used to a ratio around 125 inches.
I don't know if that figures into anything, but that's what I get from using online ratio calculators....
Putting all the figures into here http://sheldonbrown.com/gears/
My MPH is about right, 31.7 at 100rpm....
I don't know how this is all worked out. But I know I don't have enough gears
http://www.recumbents.com/wisil/gearinches.asp if you have a wheel diameter of 20 inches, 52teeth front, 9 back you will have 115 gear inches.
Cadence, speed:
60 - 21
70 - 24.2
80 - 27.3
90 - 31
100 - 34
110 - 37.7
therevokid [985 posts] 4 years ago
Bedfordshire Clanger [344 posts] 4 years ago
You will probably need a new front derailleur to cope with the bigger difference in teeth between the big and middle rings.
I think those measurements are for a 451 20 inch wheel SammyG, Mine are 406
Thanks revo, they are 130's
Clanger, I wont need a new deraillieur, just move it slightly up the post, plenty of room to do it  3
Does your front mech not have a limit to the difference in number of teeth that it can handle? You are proposing a change from 22 to 25.
Not that I'm aware, when I had it in the LBS to have the shifter replaced, I spoke to them and they said I can just move it up the post slightly.
