With all this snow I have been mostly riding a turbo in my garage. After each ride I have a pile of rubber particles (about 1mm in size) on the floor behind the bike. It's a TACX magnetic trainer (usual friction drive setup) - is this a sign of too much/too little tension, tyre pressure, worn turbo or just one of those things that happens with a turbo?
ta
Jimmo
13 comments
thereandbackagain [173 posts] 5 years ago
Turbos will shred a normal road tyre.
I bought the cheapest 10 spd wheel I could find, a cheap 10-spd cassette and a Continental turbo tyre, which works fine.
cidermart [502 posts] 5 years ago
Agreed proper turbo tyres last much longer than your normal road ones.
KiwiMike [1325 posts] 5 years ago
Get a rim drive one? Loads quieter, no tyre/mess issues. Had a Magura one a while back, worked very well once set up. Anyone know of any downside to them?
Gkam84 [9110 posts] 5 years ago
Yeah, they won't run on disc brake rims  19
MickeyBlueEyes [15 posts] 5 years ago
Do turbo specific tyres work as they should on rollers too ? If so would just one on the rear suffice ?
Simple answer yes, in my expirence, as you have more weight over the rear wheel, as on the road, it wears out quicker so it should work.
Bobbys boys [76 posts] 4 years ago
I have a Minoura rim one and love it. No wear to anything much.
adambird [4 posts] 4 years ago
Would definitely +1 the Continental Turbo tyre. Those things are bomb-proof, mine seems to be lasting a lifetime
Fringe [1047 posts] 4 years ago
Cheap option is to use your old tyres. Or head down to your LBS, if there anything like mine, they will have a box of old tyres that can be had for a few quid.
toetruck [16 posts] 4 years ago
+1 for old tyres. Cheapest and best option, but if you want to take to the road too, you'd need to have a second rear wheel so as not to be on the road with garbage tyres. If it helps, I use an Elite Chrono Fluid turbo and Specialized Armadillo tyre... there is always a small amount of rubber dust when I fit a brand new tyre, but that stops after a couple of sessions. After that, there is no noticeable wear at all on the tyre. I don't know if it's the roller compound or the tyre compound or a combination, but I've used the same tyre on the turbo for two years and it looks like a new one.
mbr4dy [20 posts] 4 years ago
+1 the Continental Turbo tyre...there is barely a whisper, whereas normal tyres are extremely noisy I find
badkneestom [135 posts] 4 years ago
That's why I set my BB up on a tree stump and freewheel it hardcord
giff77 [1288 posts] 4 years ago
 24 24 24 Pure class.
