I am currently browsing the world wide web for a suitable wheel set for my budget and have come across "Spin Cycle Works".
They produce a Carbon Clincher handbuilt wheelset that has quite taken my fancy. It sits right on my budget of about £600.
http://www.spincycleworks.com/servlet/the-67/CARBON-TUBULAR-50MM-HANDBUILT/Detail
(I know the link says tubular but it will take you to the clinchers)
My first question would be whether anyone here has experience of buying/using wheels from Spin? Also, do you guys have any thoghts on Carbon Clinchers?
The other option that is sat right up there are a pair of Campagnolo Eurus Black.
http://www.ribblecycles.co.uk/sp/road-track-bike/wheels-factory-built-wheels-factory-road-tri-campagnolo-eurus-black-clincher-wheels-pair/campwhfr417
What are your thoughts on the 2 wheelsets?
Many thanks
3 comments
SamShaw [266 posts] 4 years ago
Have you checked out http://www.wheelsmith.co.uk/ ? Might be worth giving Derek a call and discussing your requirements.
I'd love a set of his carbon wheels!
titusrider [25 posts] 4 years ago
If your really want good value carbon clinchers try here:
http://www.light-bicycle.com/carbon-road-bike
if it was me and i was going for 'cheap' carbon i would stick with tubs as you are less likely to get QC or heat build up issues in which case on-one have a good set
scaramanga [31 posts] 4 years ago
Thanks both.
@Sam - I have dropped the wheelsmith a line to discuss
@titusrider - That was my concern (heat failure) about the Carbon Clinchers. The Campags are definatly the safer bet in that respect.
