Sram Apex upgrade to Red advice needed
Udinese, January 16, 2013
Hi,
Currently my groupset is Apex compact set 50/34T 110 165mm crankset gxp , 11-32 PG1050 cassette n Apex FD/RD
Do I need any specific request for my Red Sram 2013 5 pc groupset plus I'm planning to use Qrings n 3d crankset
One of the dealer email this info
Rotor 3D Compact 165mm Crank Set, 110 BCD
Rotor Q Rings Compact Set 50t/34t, 110 BCD
Sram Bottom Bracket GXP ( if you are using this bottom. Bracket with the rotor crankset then you will need a rotor bottom bracket as the SRAM GXP will not work with the rotor spindle. So this quote includes the rotor English bottom bracket)
2013 Sram Red Yaw Front Derailleur
2013 Sram Red Aero Glide Rear Derailleur
2013 Sram Red XG 1090 Powerdome Cassette (what ratio to get?)
2013 Sram Red Ergo Shifters
If you are replacing the groupset you may as well replace the bottom bracket at the same time so just but the appropriate bottom bracket for the crankset you decide on....
Cassette depends on your fitness, strength and the sort of riding you do. If you need the 32 rear at the moment then get it on the new cassette as well!
posted by jimmo62 [55 posts] 16th January 2013 - 9:09
That's quite a jump in price and performance. Given the weight you'd save in upgrading, I reckon an 11-28 cassette would do you for all but the steepest of steep hills (34 x 28). For the price of a BB I'm with Jimmo62 - get a new one.
arrieredupeleton
posted by arrieredupeleton [396 posts] 16th January 2013 - 11:03
As for BB, you can use any Shimano type that has a 24mm axel. I'm using a Hope bb with regular bearings.
posted by boardmanrider [45 posts] 16th January 2013 - 14:43
Do you have especially short legs? 165mm cranks are quite short. Don't go bigger than a 28 on the back, 32 is for mtb...
posted by nappe [26 posts] 16th January 2013 - 14:58
Don't forget that you will need to get the WiFli rear deraillure if you want to use a cassette larger than 28T. Personally I run an 11-28 with compacts in Red and I can get up 15% + gradients and I am definitely not the strongest rider in the world. The 11-32 will allow you to spin a bit faster up the hills but you will increase the spacing between gears. This may make it a little harder to get the right gear sometimes. It is really a personal preference in the way you wan to ride. There is nothing wrong with using a 32T cassette if that works better for you.
posted by Jason.wellington [3 posts] 16th January 2013 - 23:34
Leg inseam is 29"
posted by Udinese [3 posts] 17th January 2013 - 6:25
Calendar
