Carbon Seat Post in Alloy Frame??
Gman59c, January 3, 2013
Hi, newbie here looking for some advice.
I have an alloy bike that I am using for commuting and winter training rides, and I also have a carbon road bike that is currently in hibernation.
I am looking at some upgrades primarily for the alloy bike. I had thought that I might get a carbon seat post and new saddle, the idea being that I could then swap the set post over when the better weather comes along.
However, I have came across a comment on anther site saying that carbon posts should not be used on alloy, due to corrosion and slippage.
Can anybody confirm that this is the case?
Thanks
Been riding an alloy frame with carbon seat post for the last two years as a winter trainer/commuter. Not experienced any problems so far.
posted by Psycling [29 posts] 3rd January 2013 - 20:04
Agree with the above, had a carbon post in an alloy frame for years with no problems
posted by jimmo62 [51 posts] 3rd January 2013 - 20:21
I have a carbon seat post on my alloy frame and no issues at all.
posted by stepho [65 posts] 3rd January 2013 - 20:34
a lot of alloy bikes come spec'd with carbon posts so it really isn't a problem.
TheHatter's picture
posted by TheHatter [736 posts] 3rd January 2013 - 20:42
Yep, got a Carbon 'mast (as I think I may start calling seatposts now) in my S1 with few problems.
Just give it a wipe with a cloth every few weeks to stop grit scratching it up.
There have been stories of 'masts getting stuck, but tbh they probably left it in there for about a year. Its only if you cycle by the sea (which I do), where the salt can kick start electrolysis when you need to be a little proactive, otherwise, you'll be fine. Smile
My alloy post did get stuck in my steel Condor, but that's a different story...
Sir Velo
Raleigh's picture
posted by Raleigh [1509 posts] 3rd January 2013 - 22:19
Not a problem - put some grease on the post to stop it from sticking if it's a very tight fit and don't clamp it too hard.
Ah! Condor
posted by Bedfordshire Clanger [208 posts] 3rd January 2013 - 23:09
Excellent news, thanks guys!!
I have just ordered a new Fizik Cyrano Carbon post and was looking forward to trying out this weekend.
All systems are go!!
posted by Gman59c [16 posts] 4th January 2013 - 9:37
added bonus of a carbon post in an alloy frame is "buzz"
reduction ... Smile
still on the 3rd switch-back of Bwlch !
posted by therevokid [441 posts] 4th January 2013 - 9:53
DO NOT put grease on your carbon seatpost in an alloy frame. over time it expands the carbon which will then be near enough impossible to take out of your frame or adjust.
some companies say use carbon specific grease but i wouldnt use this eaither. you are better off no grease at all and setting it to the correct torque.
Copied from another site :
From Easton:
No grease on carbon posts. Grease contains certain minerals that can attack clear coats, can penetrate the resin matrix and could cause swelling of the composite laminate. Can you say "stuck seat post?" Don't use grease.
John G. Harrington
Vice president, bicycle products
Easton Sports, Inc.
From Campagnolo:
No grease. In some cases it can be dangerous to use grease as the chemical composition can cause a reaction between materials. Besides, it increases the torque required to clamp the post.
Richard Storino
Campagnolo USA
From Deda:
Absolutely no grease on carbon, ever. Also, do not use solvents to get old grease off, or to get old grease out of the seat tube. John Harrington of Easton and I believe that many solvent residues in the seat tube soften the gel coat of the carbon, then bond the gel coat to the inside of the seat tube, freezing the seat post in position for eternity.
Tom Franges
Deda Elementi North America tech support
posted by Lost faith in t... [89 posts] 4th January 2013 - 11:15
You could use the carbon fibre grip paste if the post slips, I assume that is what it is designed for.... I have used it in the past. However if you can get away without it seems that from the above posts the manufacturers prefer it.....
posted by jimmo62 [51 posts] 4th January 2013 - 11:32
we use it on carbon posts in carbon frames but when its aluminium and carbon it sill tends to cause problems with the materials bonding together.
we normally get 2-3 customers a year who have used carbon paste/grease who ask us to try and remove there post for them but there is no chance.
they normally have to go to an engineering firm to get the post reamed out or try some home brew remedies of chemicals which normally make matters worse lol.
posted by Lost faith in t... [89 posts] 4th January 2013 - 11:41
