How to carry out an emergency repair on a slashed tyre:
https://www.youtube.com/watch?v=y43AqMJoxHI&feature=plcp
www.cadenceperformance.com
Keep cycling!
10 comments
Super Domestique [1619 posts] 5 years ago
Cool.
Those little 'get me home' tricks are useful.
pirnie [199 posts] 5 years ago
Brilliant! Why did I not think of that!
giff77 [1288 posts] 5 years ago
A fiver also does the trick. Though depends if the damage is pre or post coffee stop  3
londonplayer [621 posts] 5 years ago
*stupid comment time*
I've changed my inner tube, pumped up the tyre to high pressure and carried on using my outer tyre in the past. Surely you'd need to have a hell of a slash in the tyre for it to fail whilst pedalling home?
gthornton101 [160 posts] 5 years ago
nifty little trick!
bikecellar [268 posts] 5 years ago
Once used a Tesco Clubcard to repair sidewall damage!
Spangly Shiny [163 posts] 5 years ago
Or simply carry a section of an old tyre with the bead removed. That way, because you have it, you know you'll never need it.
Municipal Waste [252 posts] 5 years ago
Quite often you can find that even a 1cm cut in a tyre's side wall can cause a blow out once you get as far as about 60psi. Usually in the tread of the tyre you can get away with it as there's a bit more material (unless you love skidding about on a fixie).
Oh and Zip Vit energy gel wrappers are perfect for the job  26
Knew there was a reason I keep an extra Zip Vit gel in my saddle bag! Just a shame they taste like wallpaper paste!!
