I need a cable guide...........
stuke, November 20, 2012
I'm building up a new steel frame and I need a BB shell cable guide that is a push fit with a little nub in the back rather than a screw. There is a hole in the frame but its not threaded.
After much googling I still can't locate one.....any ideas people
personally ... i'd tap the little blighter. they're only
M4 or M5 so not huge. That does pre-suppose that you can
of course - is the existing hole small enough to be
tapped ????
or ....
http://www.petracycles.co.uk/push-cable-guide-nylon-p-64646.html
Any use ????
still on the 3rd switch-back of Bwlch !
posted by therevokid [448 posts] 20th November 2012 - 11:09
give your LBS a call, they probably have a dusty box of them, if that fails try calling Ceeway, they're a framebuilding suppliers so probably also have a dusty box of them
posted by VecchioJo [634 posts] 20th November 2012 - 11:43
tapped ????
or ....
Any use ????
yeah tapping is an option, I haven't measured the hole but it looks about 4mm dia so should be fine. I found the one you linked to but can't find anywhere in stock.
It's annoying as I had one of the push fit guides in my sapares box until I had a clear out a couple of months ago
stuke's picture
posted by stuke [217 posts] 20th November 2012 - 11:45
Ah Ceeway, it's Columbus tubing so that might be a good option - cheers
stuke's picture
posted by stuke [217 posts] 20th November 2012 - 11:47
posted by Bobbys boys [81 posts] 20th November 2012 - 13:33
Calendar
