Hi, I'm after a chainring for a single speed conversion. Nothing fancy reqd at all, just something 5 bolt, 110 BCD. Preferably in a 50 tooth or thereabouts variety.
Condition doesnt matter as long as it is rideable.
And hopefully as cheap as possible!
Thanks!
7 comments
Gkam84 [9098 posts] 4 years ago
If its only the chainring you are after, can't go wrong with these
http://www.ebay.co.uk/itm/Brev-M-Brev-M-Messenger-Chain-Ring-Road-Fixie-...
BUT if you want different, find a drilled one  3http://www.ebay.co.uk/itm/Stronglight-Alloy-Chainring-5-Arm-48-Teeth-50-...
If you are looking for anything else single speed, look at my for sale fixie  4
trikeman [309 posts] 4 years ago
Hi Cooks,
just been out the 'garage of many bike bits' and found deep in the vaults, a ring that may help though it's not as big as 50 (50 for a fixi????). I have an extremely light, 5 lug, 110mm bcd 36 tooth (I bought it for a fixi a while ago) it's an Sram red and was only on for a few weeks with low miles - didn't get on with the fixi.
It was actually an inner red set ring (choice of 34, 36 or 39 - this one is the 36).
If it's any good let me know.
Regards,
Trikeman.  3
Cooks [494 posts] 4 years ago
Thanks for your help guys! Yeah, I'm after something rather large (I'm something of a grinder I'm afraid) so a 36 is a bit small. Thank you very much though. GKam, the messenger ones look good but are all 130bcd. I'd have to get a crank to fit, I aready have a 110 crank ready to go. I used to have the chainring to fit it but God only knows where it's got to.
The drilled one id an option tho. But will hold out a bit longer to see if anyone has something lying around in the shed
 1
Raleigh [1667 posts] 4 years ago
Try spa cycles, I've bought chainrings for youth gears from there, cheap and quick.
50 is pretty big for a fixie, meake sure you know what you're doing or you'll screw up your knees.
I sometimes struggle to go up **sharp** hills and I have a 48x15...
 22
Awww Raleigh, you need to build up your legs a bit, I've been riding 50/15 lately, but used to ride 55/13  3
It's gonna be single speed, not fixie. It is big, but I've run 50x14 before pretty comfortably.
Thanks again
Big Gears aren't good for little legs  20
