looking at getting a turbo trainer, and thinking about a spare wheel to interchange rather than having to swap tyres.
I currently have a 11-25 on the rear, and am looking at going to 11-30 for the road (to give my knees more assistance) and keep the 11-25 for the turbo wheel.
will i be able to keep the set up the same, or will I need to adjust the chain length and cable tensions?
5 comments
thereandbackagain [172 posts] 3 years ago
You may find that the current chain is too short. If you go up to a 30 then the derailleur may be pulled too far forward if you went for a big at the front, big at the back combo.
You may need to get a new chain and leave more links in it. After fitting the new cassette see how the derailleur hangs with regard to the reference installation instructions.
robert.brady [155 posts] 3 years ago
Your chain probably could do with a few more links but as long as you avoid the big-big crossover gears you could get away without them.
I think the most likely problem you may encounter is whether or not your rear mech can handle a 30t sprocket.
Rob
kevarino [22 posts] 3 years ago
I'm pretty sure the largest shimano short cage rear mechs can take is a 28t, it will depend what you have and check it on the manufacturers technical section.
FMOAB [266 posts] 3 years ago
Depends on the mech. If it doesn't have the capacity, you may find that you jockey wheels ride on the cassette. You can adjust it a little with the adjustment screw that rests on the rear dropout, but I would go with the manufacturers spec. Shimano tech manuals are easily found online - don't know about the others.
Oh and I would be astonished if you didn't need a longer chain, so make sure you factor that in to your costs.
Mostyn [396 posts] 3 years ago
May I suggest you go for a 11/28 cassette? two teeth less than a 30, but you would probably get away with using the same chain you now have for your 25, tooth cassette; and your deraluer would cope perfectly with a 28, tooth sprocket.
