Quick question (with hopefully a straight forward answer)
I have just bought a Wilier frameset with an Italian BB - it has got a Campag Athena BB already fitted.
Can I build this up with a Sram Rival chainset?
Will it fit?
Will it perform OK?
That is all.
Thanks
4 comments
ficklewhippet [76 posts] 3 years ago
Hi,
Your Campag BB will probably be superfluous (it's not compatible with the SRAM chainset in any case).
The SRAM Rival chainset should come with its own BB (GXP). It should fit your frame no problem. Same tool required to fit it as the Campag one I believe (a large flat spanner with internally splined teeth).
I've got a SRAM Rival compact chainset on the commuter and it's absolutely fine. Some play in the bearings but otherwise all good!
mathewshotbolt [90 posts] 3 years ago
even if your rival chainset comes with a bb, it'll be english thread and not italian.
you'll need to buy another with an italian thread.
big mick [183 posts] 3 years ago
Yea spot on Italian size diameter is i think73mm english68mm and campag is not conpatable
JC [157 posts] 3 years ago
All sorted - bought a BB Italian GXP Sram
Fits and works like a dream  3
