FSA BB30 adapter sleeve removal
lazyusername, September 20, 2012
I've got a Ribble stealth I built up in the spring, and I can't seem to get on with it. It seems pretty brutal on my legs but not in a way that Ive had from cycling before. I have come back with bruising on my calves over the summer.
Anyway ive looked into what everyone else thinks of the frame set on the web etc andI haven't found anyone else with a bad word to say about it so the only thing I can think of is the FSA adapter sleeve in the BB which I've got to let me use a standard chain set I already had with the frame. I've created an additional metal on metal contact point inbetween the BB and chain set. I think this is transferring a load of road buzz up through my legs.
Is this something anyone else has had experience of and has removing the adapter sleeve solved the problem. Secondly how do you remove the adapter sleeve and can it be done at home or is it a job for the LBS
Thanks in advance
To me, Its a step to far IMO, Its a LBS job, not that I have anything with that kind of BB. But here is a step by step
http://www.parktool.com/blog/repair-help/bb30-bearing-system-installatio...
Gkam84's picture
posted by Gkam84 [6439 posts] 20th September 2012 - 19:48
I removed the sleeve from my Orbea Orca so that I could run BB30 and Wheels manufacturing adapters instead.
To remove it we used a headset press (posh park one) and a round halfords chrome exhaust extension.
Strangely enough, I've just used the same extension to fit my 1.5in race to some tapered forks as they only had a 1 1/8 tool handy.
posted by charlierevell [14 posts] 21st September 2012 - 16:50
