Rest Day Transfers?
1) If I take one spare transfer into the rest day will I come out the other side with 5 transfers or lose it and just have the usual 4?
2) If I do take five transfers into stage 10 (Vuelta) and only use 2 will I still have 5 again for the TT (stage 11) or lose the saved transfers and only have 2?
Anyone able to confirm the situation please?
The most you can roll over is 2, So on a rest day you can have 6 and then any other time its 4
Gkam84's picture
posted by Gkam84 [6465 posts] 25th August 2012 - 23:43
Ok, thanks.
posted by memories of meseeuw [17 posts] 26th August 2012 - 0:08
ignore
posted by Lost faith in t... [92 posts] 26th August 2012 - 12:05
So, Gkam/Dave, if I don't use any of my four rest day transfers do I
a) carry over all four to use, plus two from Tuesday thus having 6 for the ITT
b) carry over four but cap out at four so I can only use a max of four for Tuesdays ITT
Just want the official line before I start overhauling my team.
posted by drheaton [2404 posts] 26th August 2012 - 21:30
The MOST you can roll over is 2.
So the most you can have any normal day is 4, on rest days, If you make no changes, You will still only roll 2 over. So today and tomorrow you could have up to 6 transfers the rolled over 2 + 4 for the rest day.
If you choose to make any number of changes. You will only have 4 on Tuesday for Wednesday's ITT
Gkam84's picture
posted by Gkam84 [6465 posts] 26th August 2012 - 21:41
So, if I make no rest day transfers only 2 of the 4 will roll forward giving a maximum possible transfers for the ITT of 4. So, I can use up to two rest day transfers and still have 4 for the ITT.
That makes sense I guess.
posted by drheaton [2404 posts] 26th August 2012 - 22:43
Yeah, if you make changes today, you can roll 2 over and have 4 for the ITT
Gkam84's picture
posted by Gkam84 [6465 posts] 26th August 2012 - 23:17
Next year I hope we get to roll over up to 4. Or maybe all we want! Smile
Sometimes, like for the rest day, you're forced to use 2 so they won't go to waste. It'd be cool to be able to bank them and use them at will instead of losing them because you don't use them...
posted by enrique [288 posts] 27th August 2012 - 20:12
And so just to clarify... if you then only use 2 for the ITT you'll have 4 coming out of the other side, right?
posted by memories of meseeuw [17 posts] 27th August 2012 - 21:30
Yes, if you continued to use just 2 per stage, you would have the option to use 4 until you use more than 2 (if that makes sense?)
My plan is to use 3 for the ITT, so i have 3 for stage after that
posted by TERatcliffe26 [2795 posts] 27th August 2012 - 21:50
Ok thanks. That's as I understood it then, so that' a relief. I used 2 today in ITT anitcipation so that I only need to use 2 more for ITT and then still have 4 out the other side.
posted by memories of meseeuw [17 posts] 27th August 2012 - 22:02
