Hi, I bought some nice new tape at the weekend, and when I started to remove the current stuff, it's so sticky that it has left chunks still on the bars. Any tips for something that will lift the remnants off? Would white spirit do it?
Also, I forgot that black insulation tape had been used underneath to hold the cables in place - presumably anything capable of lifting the glue under the bar tape would also lift the insulation tape? I'd rather not bother replacing that if I can help it.
10 comments
VecchioJo [413 posts] 5 years ago
pick away at the lumpy chunks with your fingernail and then have a go at the rest with nail varnish remover, the electrical tape will be okay
thereandbackagain [173 posts] 5 years ago
Generally I find meths also cleans it up, and is a bit less agressive than nail varnish remover.
oh, and lighter fluid can work as well, everyone has lighter fluid in the house, right?
 7
i mostly end up using a mix of whatever solvents are available under the kitchen sink
notfastenough [3729 posts] 5 years ago
 7
And having used this approach of mixing various chemicals, do you still have a bike? Do you even have eyebrows?  19
Cheers for the info guys, now need to get it sorted before the Wednesday club run.
yes, and i now have a large pink rabbit, with yellow spots, that only i can see
Darthshearer [134 posts] 5 years ago
Had something similar myself last week, was a right bugger until I used methylated spirit. Worked a treat.
Cooks [496 posts] 5 years ago
Anything solvent really. White spirit is great. Stick some in a spray bottle and it works a treat. Just dont get any on your bearings.
Gkam84 [9119 posts] 5 years ago
Lighter Fluid +1  3
Other than that, petrol or meths works a treat.
As said above, go under your kitchen sick, get everything thats "harmful" and "toxic" mix it all in a bottle, put on some rubber gloves and bobs your mothers brother  4
giff77 [1306 posts] 5 years ago
Tried that one gkam. Stopped when the bottle started to smoke!!
Gkam84 wrote:
Lighter Fluid +1  3
Swiftly followed by a puddle of carbon fibre!
