how often do you pump yours tires?
dave95, May 26, 2012
I seem to have lost 12 psi out of 100 in two weeks.. so 12%
This is after about 10 rides
I don't think theres anything wrong with the tubes, unless the valve screw cap (presta) isn't sealing well enough
twice a week sometimes 3 times.
TT bike tyres deflate every 3 days so i just put them back up to X PSI.
Smile
Coveryourcar.co.uk RT Tester.
steady rider's picture
posted by steady rider [7 posts] 26th May 2012 - 19:52
Some tubes lose more than others but 12 psi over a fortnight isn't so bad. If it was overnight I'd be more concerned (excepting latex tubes, which are considerably less airtight than normal butyl ones).
The cap is only keeping dust and crud out and the threaded locknut prevents it opening accidentally, I believe it's the pressure of the air inside that keeps it closed.
Simon E's picture
posted by Simon E [1320 posts] 26th May 2012 - 19:53
The narrower the tyres, the smaller the volume and higher the pressure, the more often they need to be re-inflated. 12 psi from 120 in two weeks is a lower rate of loss than I'd expect, so you are doing well. I pump up 90 / 100 psi 25 mm tyres once a week. 26 x 1.6 " tyres on my winter commuter at 80 psi only need pumping up every fortnight, at most.
The loss of air is through the fabric of the tube. There's nothing you can do about it.
two wheels good; four wheels bad
posted by cat1commuter [1187 posts] 26th May 2012 - 20:23
Probably a couple of times a week. Your tubes will loose pressure regardless. More so when they are latex. And as simon says the presta's seal from the pressure of the tube. If they were losing pressure every couple of days then you may have picked up a slow puncture.
giff77's picture
posted by giff77 [701 posts] 26th May 2012 - 20:39
I ride two or three times a week and pump them up before every ride.
posted by notfastenough [1980 posts] 26th May 2012 - 21:09
For me, this ^
posted by Super Domestique [1120 posts] 26th May 2012 - 21:55
Life without performance bikes is a lot easier Smile
I ride a bike everyday and most weeks do not pump up any tyres.
For example yesterday I pumped up the back tyre of my Bullitt Cargobike for the first time since I fitted a new tyre on 18th March. The tyre is a Schwalbe Marathon Plus Tour 26"x2"
On my road bike I run Schwalbe Marathon Classics 700cx28mm and again I would be surprised if I pump them up more than once a month.
On my Peason fixie I run 700cx25mm, again I pump them up less than once a month.
All these bikes get used multiple times a week and due to the road quality here I don't let them get soft cause otherwise I always get pinch flats.
I run cheapish inner tubes (Continental Quality Road Pack of 5 Inner Tubes Cross 28's from Wiggle).
So my guess is that small diameter tyres have 2 disadvantages a) higher pressure so more likely to loose air b) smaller air cushion so need to keep pressure higher and more consistent to avoid pinch flats.
I'm happy to stick to bigger volume tyres Smile
posted by Dave42W [12 posts] 26th May 2012 - 23:27
I will add my experience of at least once a week for my road bikes, and every couple of weeks for my MTB
I'm riding the 2013 Giro d'Italia for charity! Check it out and follow my progress live at www.tourletour.com
Tour Le Tour's picture
posted by Tour Le Tour [89 posts] 27th May 2012 - 0:19
I do mine every ride, then deflate when i come home and store the bike in my bedroom
Gkam84's picture
posted by Gkam84 [6491 posts] 27th May 2012 - 2:23
gkam,
is that an anti-theft measure or for other reasons?
posted by londonplayer [652 posts] 27th May 2012 - 6:52
I suspect gkam also stores his tongue in his cheek.
joemmo's picture
posted by joemmo [421 posts] 27th May 2012 - 8:44
I pump up my tyres every time I clean the bike.
So after rain basically.
Devil
Sir Velo
Raleigh's picture
posted by Raleigh [1520 posts] 27th May 2012 - 12:26
Not any other reason than i store mine in my travel case, Saves having a bike just lying around my room, So deflate and pack away. Bit of a pain, but it keeps the place looking tidy Big Grin
Gkam84's picture
posted by Gkam84 [6491 posts] 27th May 2012 - 14:16
before every ride - if your tubes hold air too well, you are not going fast enough (they are too heavy) and if you do not play with your pressure you will never go fast enough...
roadie come mountain biker come single speeder and back again
posted by cborrman [84 posts] 28th May 2012 - 17:17
As with Gkam i pump mine up every ride and deflate after each ride as i store my bike off the ground - not that that makes any difference - i just dont like the tubes being constantly at a high pressure
Stumpy
stumps's picture
posted by stumps [1564 posts] 28th May 2012 - 19:21
every ride for me,
posted by russyparkin [444 posts] 28th May 2012 - 22:06
A track pump by the front door helps, I found. Easier to remember and running the right pressure makes for a better ride. Agreed with the various points on low volume high pressure means more pumping. I keep my GP 4000s at 110 ish and they'll drop maybe 10 a week or so. My brompton with marathon plus seems to hold the pressure better, so 90 for a week or more, mountain bikes fortnightly.
Cannondale CAAD10 and an Orange Brompton M3L
bike blog - headtu.be
zzgavin's picture
posted by zzgavin [164 posts] 29th May 2012 - 9:19
yep, should be at least once a week for my road bike. My town bike's lucky if it gets pumped up once a month or less!
PJ McNally's picture
posted by PJ McNally [262 posts] 29th May 2012 - 9:30
Calendar
