FS Mavic Cosmic Elite 2012 Wheelset
gb901, May 16, 2012
FS Mavic Cosmic Elite 2012 Wheelset.
As new - used for one sprint triathlon.
Shimano hub.
Cosmic Elite has been designed for high speed addicts. High elliptical flanges coupled with high efficiency hubs and bearings quality, this is the wheel of choice for all speed enthusiasts, road racers and triathletes.
Improve your aerodynamics !
30mm deep rim
Bladed spokes
Low spoke count (20/20)
Perfect power transmission thanks to high stiffness
Straight pull spokes
Radial lacing : front and rear non-drive side
Stiff rim profile
No restriction wheelset:
Fully clincher compatible
Predictable and weatherproof braking
Aero for budget conscious cyclists
Weight: 1770 grams
RRP £355
£250 including post
Mavic 2012 Cosmic Elite Wheelset Features:
30mm deep rim
Bladed spokes
Stiff rim profile
Mavic 2012 Cosmic Elite Wheelset Specifications:
Rims:
Colour: black anodised
Drilling: traditional
Eyelet: profiled
Height: 30 mm
Material: 6106 Aluminium
SUP
UB Control
Valve hole diameter: 6.5 mm
Spokes:
Colour: black
Count: 20 front and rear
Lacing: radial front and rear non-drive side, crossed 2 rear drive side
Material: stainless steel
Nipples: brass, ABS
Shape: straight pull, bladed
Hubs:
Colour: black
Front and rear axle material: steel
Front and rear bodies: aluminium
Front axle size: 9x100
FTS-L, steel
QRM
Rear axle size: 9,5x130
Mavic 2012 Cosmic Elite Wheelset Technologies:
FTS-L - FTS-L: Force Transfer System Light: The reinforcement of the key transmission components.
Lighter hub
Stronger hub
Better torque transmission
QRM - Qualité de Roulements Mavic (Mavic bearings quality): Mavic only uses high quality sealed cartridge bearings. On QRM wheels, they provide high durability thanks to double sealing (2RS or LLU) as well as high efficiency thanks to C3 internal clearance (low play, tight tolerances).
SUP - Soudé Usiné Process: A welded and milled rim joint is extremely strong, eliminates shuddering when braking, and offers superior wheel balance.
UB Control - Usiné Brut Control: The braking surfaces are milled to improve braking friction and eliminate shuddering.
Compatibility:
ED10 or M10
ETRTO size: 622x13C
Recommended tire sizes: 19 to 28 mm
Tire: clincher
forum post associated image
Mind if I ask why you're selling?
posted by notfastenough [1981 posts] 17th May 2012 - 12:51
Hi there, Are your wheels still for sale? I am very interested if they are. Thanks
posted by xtrojt [1 posts] 18th June 2012 - 7:55
Sold
gb901's picture
posted by gb901 [83 posts] 18th June 2012 - 10:35
Calendar
