Carried over transfers
Interesting to note how carried-over transfers are working with two races simultaneously. I was carrying forward one transfer on the Giro. However, with both windows open, it shows 3 available for ToC, and 2 for Giro. presumably if I only use 2 at ToC, the Giro one will update to 3 once the ToC window closes.
It does open up an interesting possibility during overlapping races of doing one race as a purist, and getting double the transfers in the other one!
I used no transfers between stages 8 and 9 and still only had 2 for the slot between stage 9 and 10(used both).
I have used 2 in the TOC between stage 1 and 2 but surely that shouldn't compromise those I've saved the Giro?
I guess it is inevitable there will be a few teething problems before everything is ironed out.
looking into it!
the rollover should be working on a per-competition basis. we've updated the game engine.
the rollovers are generated automatically for the next stage to start. that means the AToC ones are done and the Gito ones will update after the transfer window for the AToC closes. however, we're looking to move over to a system that updates all competitions individually so you don't have to wait.
Looked at my transfer history and definitely used no transfers in stage 42(Giro S9) so should have had 4 for stage 43(Giro S10).
Currently used 2 for stage 43 and have none left when should have 2?
Quote:presumably if I only use 2 at ToC, the Giro one will update to 3 once the ToC window closesthe rollover should be working on a per-competition basis. we've updated the game engine.
OK
I understand
Thanks for dealing with this so speedily!!
COMPUTER SAYS you have two rolled over transfers still available?
[...however, we're looking to move over to a system that updates all competitions individually so you don't have to wait.
I think that's quite important - a whole bunch of us won't be in a situation where we can do transfers during the day - it all has to be done in the 'after the kids are in bed' window each evening.
road.cc on YouTube
8 comments
