Was aiming to have 2 transfer roll through to the rest day, so I will have 6 for Wednesday's TTT. Use 4, roll 2 through Thursday (will using 2) to the spend 4 for the 1st uphill finish of the Giro on Friday.
Dave is my logic right? Or because the But if you don't use that extra transfer on the next day, you'll lose it. I will lose the 2 transfer tonight because there is a rest day and you can't use transfers, therefore you lose them
4 comments
dave atkinson [6370 posts] 6 years ago
looks right to me  26
transfers not used for today will roll over to weds, and if you use four on weds it'll use the rolled over ones first
nickobec [246 posts] 6 years ago
Good because, waiting for the answer I forgot and missed today's cut off point and did not use today's transfers
6 transfer to use before the TTT, I assume I need to use 4? Only two will transfer over to the following day.
Simon_MacMichael [2513 posts] 6 years ago
 39
Good point, I've got six too, should check that out myself.
Ruing not transferring Cav out for Farrar yesterday, thought Tyler would be up there with the stage commemorating Wouter Weylandt.
Then again, I'm pretty sure Cav would have won if Ferrari hadn't taken him out.
