Right i know at some point a while back i asked about fitting a larger rear cassette when i was getting a mate to come road cycling with me on the weekends.
So i was doing up my winter bike so he could cope on the climbs.
The climbs never came about because he was just enjoying some of the shorter ride's i do. But all winter he's been on a turbo trainer and getting his legs ready for some climbs.
I'm still concerned about his ability and don't want to put him off the first time we hit the lecht, soooooooo.....
I know this is not the done thing and it goes against my better judgement, but i don't have the money to be forking out on an old bike that i rarely get round to using.
Could i fit this groupset, while still retaining the STI's that are on the bike and get away with it?
My STI's are double and 8 speed, so i know that i'm not going to get the full range of gears, but i can adjust the derailleur to give him the biggest range for climbs?
Unless anyone can point me in the direction of a sub £125 road groupset?
http://www.ebay.co.uk/itm/Shimano-Acera-9-27-Speed-Drivetrain-Bicycle-Gr...
20 comments
giff77 [1270 posts] 5 years ago
Gkam. It looks doable. I've added a link to the ctc forum below. Can your wheelset be upgraded to a 9 speed cassette though? If so, it looks like your main challenge will be your cable pull and working out how to forgoe cog9 http://forum.ctc.org.uk/viewtopic.php?f=5&t=43400
It may though be cheaper to go with your original plan and use an 8 speed cassette with larger 1st cog and pick up a derailure with a long cage to cope with the extra teeth  4
Gkam84 [9104 posts] 5 years ago
Yeah my wheel's will take the 9 speed. My idea was just to put the triple on there and if he's enjoying it, he can then pay for some triple n 9 speed STI's  19
matt637 [47 posts] 5 years ago
turbo trainer to the lecht!!! He'll need more than just a big sprocket  3
Don't know if the sti's would manage the third ring of the triple. The compact on the front with a cassette running a 30 granny ring and forgoing the 12 (if a 9 speed) may be the way forward. Either that or tell him to mtfu  19 that's what my mate told me when we climbed 'take me doon' cept he was dancing on a triple and I was grinding a sd  2
Yeah, but all that will end up happening if i dont sort something out for him to be able to spin up his own pace, is i'll get to the top and be waiting, turn back and race down to find he's on his way home because he couldn't keep up, he can manage to hold my wheel at a steady 20 on the flat, so thats an improvement from having to go 10-15 mph so he could keep up.
I'm just enjoying having a cycling partner for the first time in many years
Hope you can get something sorted out for him. I've still to find a regular cycling buddy. There's a few of us but we only manage the rare ride out together due to our schedules.
I'll sort something out for him. Just wanted to know if the STI's would work with that groupset.
Its nice to have him on the flats, even if i do all the riding and he hangs the wheel, but there aren't much flat rides around here and i'm always up hills, so would just be good to get him climbing with me as it does get boring sometimes slogging up the hills myself......for what? self punishment, lol
formereve [61 posts] 5 years ago
Hey Gkam
I might have an option for ya. Upgrading from a 9spd setup to 10 this week so will be geting rid of the 9spd parts.
They will be reasonable. Parts will be a 50/34 compact double, bottom bracket, 9spd shifters, sora front and rear mech, 9spd 12/27 cassette, KMC chain & possibly wheels too
PM me
Nige
Unfortunately Formereve, I'm around 100 miles north of that, Looks like a nice route though.
Any reason for that route?
Yorkshie Whippet [611 posts] 5 years ago
Sorry to be the bearer of bad news.
A double front probably will not work on a triple as the amount of travel of the mech will be different. A well set up front will shift between the two rings. A third ring may stretch the limits of the shifters ability to pull. More importantly the shifter will only have two index settings (plus the trim) rather than the three required.
Similary for the rear, whilst the cassette width has not changed since 8spd the distance between cogs has narrowed. The shifter will be set up for gaps of the 8spd not 9spd cassette. You may get away with it but the small difference may well throw the shifting out mid range. Or simply cause the chain to rub and wear the jockey wheels faster.
The decision you really need to make is do you want a training partner or a riding partner. Sounds like you have a good riding partner and therefore you should ride at his pace until he catches up. Rather than "forcing" him to ride at your higher pace.
dave atkinson [6307 posts] 5 years ago
i think gkam's just worried his mate's going to run out of gears and have to walk, not trying to tech him up so he can ride faster...
Super Domestique [1615 posts] 5 years ago
I just want to know why the mate has a turbo trainer but no bike  3
Dave , I agree with your sentiment. However a few of the comments from GKAM does suggets that he is looking for a training partner rather than riding partner. Namely;
"Its nice to have him on the flats, even if i do all the riding and he hangs the wheel, but there aren't much flat rides around here and i'm always up hills, so would just be good to get him climbing with me as it does get boring sometimes slogging up the hills myself......for what? self punishment, lol"
If you are out front all the time as he "hangs the wheel" and leaves the other guy behind on the hills, should you not back off the pace to make it more comfortable for him to ride? Or even stick to easier more suitable routes until the other persons ability is sufficient. Changing the gears to make it easier but still leaving them on the hills does not improve the ride for GKAM as he will still climb alone.
Or it could be my experience of being the person behind, peeved at always playing catch-up and eventually loosing interest anyway.
He's using my turbo at the moment along with my bike as i'm trying to get him out of being a "good weather" cyclist, this winter has not been so bad in terms of snow and cold weather, but he needs to harden up a bit  19
I understand what you saying, but i've gotten him from a 12-15mph rider on the flat up to my speed.
Its not a training partner i'm after, I just enjoy not riding on my own all the time. I've spent quite some time taking him out and getting him up to speed on easier rides.
He has said that he wants to go further a field and do some of the harder routes that i ride. So he's willing to come do some serious climbing. I just want to sort him out so even in the granny ring he's at a level where he can keep going. I'm not going to go shooting off up a hill and watch him struggle up. As with on the flat, i'll work him up gradually.
So i guess your right in saying its a training partner, but i'm the one training him to a level where he's comfortable riding with me.  39
Im riding the route for Derbyshire Air Ambulance. That route is being ridden on day one of 2. The 2nd day im riding this route:
http://bit.ly/pattbread.
Never gone up Kirkstone Pass but think im up for the task cause of gettin upgrades on my bike. Which is where I may be able to help you. Im going from a 9spd Sora setup to 10spd 105 groupset and Ksyrium wheels.
So im getting rid of all the 9spd stuff if ya interested. All at a very reasonable price. Contact me via my email if ya still looking to sort ya predicament.
notfastenough [3727 posts] 5 years ago
While its not great being the guy hanging onto the back of a group ride, I'd rather that than be right on the front. I get better all the time.
Realised ya need my email. formereve [at] gmail.com Happy hill climbing  4
I hardly ever ride with others, but thats how i started, on the back getting pulled along in others wheels. Thats why i dont mind doing it for others who come out with me, once i get the climbing sorted, hopefully he'll be confident enough to take some turns on the front and by the end of the summer i'm hoping to get his climbing legs up to something which can keep a decent tempo for us to go up the hills around the same sort of speed
