Hey,
I recent got a new set of cranks/front rings. Working well but then I noticed a part had dropped off then the left arm began to come loose. Thing is I don't know what it is called to look for a replacement. It is the central screwed cover for the hole on the left hand side. Just unscrewed itself and disappeared. The cranks are made by FSA.
Any ideas guys?
thanks Graeme
5 comments
thereandbackagain [173 posts] 6 years ago
It's the crank preload bolt. By the sounds of things.
cborrman [88 posts] 6 years ago
that will be a vertical dropout... sorry, could not resist  1
Lost faith in t... [116 posts] 6 years ago
http://www.google.co.uk/search?q=fsa+crank+bolt&rls=com.microsoft:en-GB:...
look like any of these? depending on what crankset you have....
Organon [36 posts] 6 years ago
Yep,
Like this
http://www.wiggle.co.uk/fsa-left-hand-crank-bolt/
but silver
Thanks, will make sure everything is good and tight!
kayakboyuk wrote:
Yep,
Like this
but silver
This is the fundamental problem with this crank design - you can't really tighten it too much, as it's only there to pinch all the components together and take any play out of the assembly. Too much torque and you'll damage the BB bearings. The bolts on the LH crank are the things that need to be done up tight.
I'd recommend that you put some threadlock onto the thread of the preload bolt to stop it working lose. It may have some pre-applied, but more won't hurt.
