Just had a confidence crisis, not sure I'm doing this right
25 comments
_Karlos_ [52 posts] 5 years ago
Base layer underneath for me.
mad_scot_rider [581 posts] 5 years ago
same here - base layer, bib then top
in the summer the base layer is given a miss
Marauder [274 posts] 5 years ago
IIRC the base layer is meant to be against your skin to draw away the sweat and stop you getting a chill. If it was over your bibs then it wouldn't do it as effectivly apart from the chest and back area where the bib doesn't cover.
chinchli [23 posts] 5 years ago
Under, close fitting next to the skin. your trying to reduce air flow (draughts) to improve insolation (at least in winter).
cat1commuter [1421 posts] 5 years ago
Under. Comfy.
fred22 [158 posts] 5 years ago
Whew,thanks that's a relief
Edgeley [418 posts] 5 years ago
Under. Helps if you need to go to to the loo.
Tour Le Tour [88 posts] 5 years ago
Yep, good to see I am with the majority on this one - under for sure
giff77 [1258 posts] 5 years ago
Has to be under  1
yarman [19 posts] 5 years ago
Def under. Stops bib straps rubbing.
I wear a base layer, then bib tights, then another base layer, then a t shirt, then a cycling jersey, then a wind jacket.
Makes me look fat.
Warm and fat.
And that's just summertime raleigh  3
Nah, in the summer its all about a sleeveless skinsuit (Cool, I know. Some would call it a Triathlon Skinsuit, but you know, #42 and all that), Shoes with no socks and my summer helmet.  4 4 4
Cooks [494 posts] 5 years ago
Under. Otherwise you have to take off everything to pee. or poop.
How vulgar  31
I see a blatent disregard of at least two rules there Raleigh  19 I suppose they are there to be broken mind!
Which rules?
Frankly, the sock rules are ridiculous, but Im glad to see that the Keepers of the Cog are out in force this afternoon.
 1
The way I see it, rules are there to be broken  3 I think I may have broken the vast majority of them  4
paulfg42 [392 posts] 4 years ago
Makes me look fat.
Warm and fat.
 13
Where are you cycling?
Raleigh [1667 posts] 4 years ago
Mainly on British Roads  4
seabass89 [212 posts] 4 years ago
Up in the arctic circle we have 1 rule in the winter:
Wool should be the closest thing to your skin  26
There's no point wearing a base layer over cutton/lycra as it basically looses its heat keeping capabilities over normal cotton.
So if your base layer is wool, it should always be under. Then if it/you get wet it will still be warm.
Thats my tip of the day!
scaramanga [31 posts] 4 years ago
Base layer then bibs for me.
Not wishing to hijack the thread as loosley connected. I see alot of riders with socks over tights, faux pas or not???
If you're wearing tights, its neoprene.
Shorts and 3/4 legnth Belgian Socks.
The #84 of the rules has been made  4 4 4
veseunr [260 posts] 4 years ago
No, you're all wrong ... definitely over  44 13
I wear mine under though  4
giff77 [1258 posts] 4 years ago
The only socks that should go over tights are shoe socks. When in socks and shorts the socks should be at bottom of calf  1
