I bought this bike last year May from Italy - It was New old stock from a shop there. I loved the look but realised that a 56cm bike is too big for me. I was going to buy a replacement frame but since found a Lynskey 54cm.
I have it in a local shop for sale now but thought i would offer it up here. The bike is near pristine ... it has only done 3 long rides in Shetland and then about 400miles on a turbo trainer.
The orig saddle Vetta is back on although I used a Brooks Swallow (for the longer nose) I also shortened the stem trying to get it to fit but to no avail. The original stem is included although the shorter one is currently in place. If interested email me richdirector(at)gmail (dot) com. or if you want more pics.... This will hopefully make a pristine italian retro ride for someone
SPEC
Frame & Fork
Frame Construction TIG-welded
Frame Tubing Material Dedacciai
Fork Brand & Model Pinarello
Fork Material Dedacciai chromoly, unicrown crown
Components
Component Group Campagnolo Mirage
Brakeset Campagnolo Mirage brakes, Campagnolo Mirage levers
Shift Levers Campagnolo Mirage Ergo
Front Derailleur Campagnolo Mirage, bottom-pull/braze-on
Rear Derailleur Campagnolo Mirage
Crankset Campagnolo Mirage, 32/42/52 teeth 170
Pedals Campagnolo Veloce clipless
Bottom Bracket Campagnolo Mirage, 111 mm spindle
BB Shell Width 70mm Italian
Rear Cogs 8-speed, 12 – 23 teeth
Chain Campagnolo Athena, 1/2 x 3/32″
Seatpost Aluminum micro-adjust, 27.2 mm diameter
Saddle Pinarello Vetta
Handlebar ITM
Handlebar Extensions Not applicable
Handlebar Stem ITM / Pinarello
Headset 1″ Campagnolo Mirage
Wheels
Hubs Front: Campagnolo Mirage, Rear: Campagnolo Mirage cassette
Rims Mavic CXP 10, 32-hole
Tires 700 x 20c Vittoria Techno Twin Tread
Spoke Brand Shuhn Lih stainless steel, 2.0mm straight gauge
Spoke Nipples Brass nipples
