Garmin 800
big mick, February 11, 2012
How do i calibrate the wheel circumference 700x25c into the Garmin 800 or does it set itself using satelites? Ive tired all ways to sort it but cant.The hand book has no mention on the matter.
You don't need to set anything, just turn it on and go.
Downhill bikes don't make you cool.
www.beeston.cc
charliemac74's picture
posted by charliemac74 [142 posts] 11th February 2012 - 20:51
It uses GPS, it doesn't need such information as wheel circumference measurements. Smile
the_mikey's picture
posted by the_mikey [137 posts] 11th February 2012 - 20:56
You need to lay your bike on its side when you first turn the unit on each time. This gives the satellites a clear view of your wheels, allowing the unit to calibrate itself for whatever bike you are riding that day. Once the unit has gained a full signal you can pick up the bike and just ride.
posted by Bez [194 posts] 11th February 2012 - 21:04
I need advice not jokes
big mick
posted by big mick [107 posts] 11th February 2012 - 21:36
big mick
Cant use gps indoors on a turbo trainer so ive fitted a cadence/wheel sensor hence my problem
big mick
posted by big mick [107 posts] 11th February 2012 - 21:39
Menu > Bike settings > Bike Profiles > your bike > Bike Details
Set your wheel size there
then Menu > Bike settings > Bike profiles > your bike > ANT+
to pair the sensor
Dave Atkinson's picture
posted by Dave Atkinson [6088 posts] 11th February 2012 - 21:44
to pair the sensor
Spot on Thanks Dave that worked a treat
big mick
posted by big mick [107 posts] 11th February 2012 - 22:02
