Repairing a Vitus bonded frame?
I have an old Vitus 979 Dural bonded aluminium frame and the bond between the seat tube and the bottom bracket has come apart. Does anybody know if it can be repaired and who could do it?
When you say 'bonded' do you mean lugged and glued? If you do that might be tricky and I'm not sure it would be that advisable either. I saw a bonded Vitus snap once - it was nearly very nasty indeed.
tony_farrelly's picture
posted by tony_farrelly [3997 posts] 26th June 2009 - 15:21
No More Nails?
Smile
seriously though, bike companies only say 'bonded' because no-one would buy a 'glued' frame, that's all it is. the strength of the bond is in the preparation of the surfaces as much as anything. The stuff they use to glue it isn't much more technical than araldite, so far as i'm aware. not that i'm advocating a DIY job Thinking Thinking
Barry Fry-up's picture
posted by Barry Fry-up [179 posts] 26th June 2009 - 16:01
Yes, the alloy tubes are bonded with a dry heat epoxy to cast alloy lugs. It would be nice to get the main tubes replaced otherwise it will remain hung up to just look at because it is pretty but probably too dangerous to ride.
It's not just about the size of your cog.
TRs Blurb n Blog's picture
posted by TRs Blurb n Blog [270 posts] 26th June 2009 - 16:10
Calendar
