Roller trainer blowout - is this normal???
by mtnaeba on January 24, 2012 - 22:33
I recently bought a Tacx Antares roller trainer. I've used it a few times and it's been fine. However tonight my tyre blew up - is this common with trainers?
I was working on improving cadence so riding a bit faster than usual up to about 24mph.
Or is it down to a cheap inner tube and tyres - recently bought a Trek 2.1 and it came with fairly cheap bontrager tyres on it in case that's the problem?
I take it you were using a normal tyre on the rear rather than a roller/turbo tyre?
Special trainer tyres have a special compound which has a much lower internal resistance
Gkam84's picture
posted by Gkam84 [3278 posts] 24th January 2012 - 22:40
Ah, no I didn't know that. Thinking I guess I need a spare back wheel to train on then. Thanks for the tip!
posted by mtnaeba [6 posts] 24th January 2012 - 22:46
Dunno. I've ridden the same rollers for two years and no problems.
Use vittoria rubino pro, 40mph sprint intervals and 30 mph ave over 50
mins is usual session. Tyre should eat 24mph.
Rollers don't kill tyres like turbos.
posted by Chrisc [97 posts] 24th January 2012 - 23:12
Normal tyres will last a certain time, depending on many things, rider weight, speed, power....etc
But you are better off using a trainer tyre on the rear as thats what they are designed for
The only hassle is they are useless for using on the road
So if you only have the one bike, like i used to, i had 3 wheels, 1 front with a road tyre, 2 identical rears, one with a trainer tyre and one with a road tyre, same cassette and would just switch them over
Gkam84's picture
posted by Gkam84 [3278 posts] 24th January 2012 - 23:20
turbo trainers and rollers do wear tyres down but i'd be surprised if they caused a blowout. what does the tyre look like where it's blown? more likely it's a gash in the carcass from road debris that's decided to go pop on the rollers and not really related to the roller time
dave_atkinson's picture
posted by dave_atkinson [4766 posts] 24th January 2012 - 23:37
Be very wary of using trainer tyres on rollers - they're designed for turbos because of the extra wear the resistance causes, you don't get that wear with rollers and shouldn't need anything other than regular good quality tyres. A good number of the riders I coach will regularly be spinning at up to a registered 55mph on rollers (no wind resistance so it's fairly easy) - I've never known a tyre blow.
At the end of the day...............................
...............................................it gets dark
------- __@
----- _`\<,_
scannings's picture
posted by scannings [14 posts] 24th January 2012 - 23:57
Not normal but not that uncommon either.
Depends on several things:
  • Was the tyre properly seated on the rim?
  • How tight was the fit of the tyre to the rim?
  • How great was the pressure between tyre and roller?
  • What pressure was in the tyre to start with?
  • Did you pump your tyres up outside in a garage at -5 then bring them indoors to +15 or 20 (increases pressure a bit)
Heating of the tyre on the roller can then increase pressure further -> if the tyre is arelatively loose fit on the rim, or badly seated, or you have a pinch in the tube somewhere, it's not unknown for the tyre to blow off the rim with an almighty great "BANG" ....
This week I am mostly riding a Bianchi Oltre 2012 with Campag Record / Super Record mix EPS ...
posted by velotech_cycling [27 posts] 25th January 2012 - 0:48
Did you tape the brakes? That could cause massive stress on the tyre, couldn't it?
posted by bashthebox [56 posts] 25th January 2012 - 12:34
It blew right on the valve. I went in to my local bike shop today and they said it is most likey that I'd pinched the inner tube when reaplcing the flat I got from a ride on Saturday. The tyre doesn't have a whole in it but it's very then where the inner tube blew up.
posted by mtnaeba [6 posts] 25th January 2012 - 14:19
I pumped teh tyres up indoors and used teh trainer indoors and tyre pressure was about 90 so should have been fine. I think it must have been as a result of a pinched inner tube Crying Won't make that mistake again...
posted by mtnaeba [6 posts] 25th January 2012 - 14:21
Never had a flat on my rollers (also antares) wher I usually sit at around 30mph, just lots of static build up. On the other trainer though (Tacx Fortius, and no, I am not endorsing Tacx in any way by owning two of their products) I get them all the time, on a trainer tyre as well Sad
I rode the Tour de France - check it out at www.tourletour.com
posted by Tour Le Tour [16 posts] 25th January 2012 - 23:44
No way! I thought I was the only one ever to get a flat on rollers! Yeah it was a bit of a surprise as I had used the same wheel and tyre exclusively for rollers all winter.
The real bugger was that it was a slow leak and I was doing intervals. I didn't want to stick on my road wheel and winter tyre so I had to jump off after every effort and re-inflate the tyre to 100psi, then jump back on just in time for my next 4 minutes by end of which tyre was back to 40psi.
Sq
Squiggle's picture
posted by Squiggle [279 posts] 26th January 2012 - 14:24
Calendar
