This morning was a nightmare for my fingers. When I got to work, I had to steep my fingers in lukewarm water to get the feeling back. I was wearing a pair of Gore countdown gloves and some wool undergloves and it still didn't stop the cold. Anyone got any suggestions of gloves that will better protect my fingers?
16 comments
andylul [410 posts] 4 years ago
My Altura Altitude gloves are the best I've ever had - never had cold fingers at any temperature, and no liners.
My feet on the other hand - blocks of ice  2
wingsofspeed68 [63 posts] 4 years ago
I recently got a pair of Madison Windshell gloves from Ribble for a Tenner and went out for a proper cold ride yesterday (-3 without the wind chill factor) and my fingers were toastie warm. I'm sure there are probably better gloves out there but if you're on a budget I can definitely recommend these.
Same as andylul though, I need something similar for my feet.
buzz [3 posts] 4 years ago
Check your shoes - Stuff toilet paper stuffed into the vents in the soles, cover with a bit of duck tape, it makes a massive difference!
Sealskins gloves - toasty!
trikeman [309 posts] 4 years ago
BBB overshoes (booties) feet like toast no wind chill at all - very comfy too. Pinkies covered with a pair of light neoprene gloves and over Altura wind defender/night reflectives, uber warm toes and pinkies makes all the difference on the commute.
Trikeman.  3
TheHatter [770 posts] 4 years ago
Also I find shaking my hands rapidly downwards (as if you're trying to shake gloves off your hand ironically) helps get the blood to your hands to help warm them.
Seen it on a Bear Grylls programme and it does work.
Andywoo [22 posts] 4 years ago
A pair of surgical gloves under normal long finger gloves works too.
Feet 2 pairs of socks plus overshoes
stuke [335 posts] 4 years ago
make sure your gloves aren't too tight as that restricts blood flow and can lead to cold fingers.
for the really cold days I find Altura Night Vision waterproof (not very breathable) outer gloves plus the liner gloves they come with. I was riding in to work at -10C last winter with no issues.
I've also found if I bung the liners on the radiator to warm them up and putting both pairs of gloves on before I leave the house, keeping the heat in, it makes a world of difference.
feet wise, Defeet Woolie Boolie merino socks plus neoprene overshoes, fine this morning on my commute when the computer said -6 degrees
rbx [226 posts] 4 years ago
Use the same gloves as stuke - Altura Night Vision - and have no problems with cold in any weather.
Feet, are a different deal altogether. Any ideas, other than overshoes, are highly welcome.
zzgavin [193 posts] 4 years ago
Making sure the gloves fit properly too helps, I used to wear gloves that bunched up off my palm when I pushed my thumb across to my fingers, then I read the fitting instructions on one of the various websites and measured around the knuckles and realised I was a tall person with narrow hands, so a small or medium fitted best. They've been the most comfortable mitts I've owned. (rapha ones if your are curious). Ignore the brand, but do check fit of your gloves, any looseness will result in cold getting in and freezing fingers. I'm using the mitts inside a pair of ill-fitting gore gloves which is ok to about -2. Long fingers and narrow hands make for difficult full finger glove fitting,
I have v snug shoes and no room for more than one pair of socks. Have Pearl Izumi toe covers that keep chill out for about an hour but should really invest in some overshoes
Cooks [490 posts] 4 years ago
Just wrap duct tape over the vents in your shoes, works a treat. I'm a cycling McGuyver.
bashthebox [751 posts] 4 years ago
I've got Sealskinz gloves, which work pretty well since they're neoprene + merino(?). Apart from the one whose stitching is coming apart. That's sodding annoying.
Feet - commuting I wear thick wool socks and overshoes. My commute mtb shoes have a smidge of room in, since I heard Sidi come up small I sized up.
My road shoes are tight, can just fit two thin merino socks inside them, but even with overshoes I'm still cold when there weather's like this.
paulfg42 [385 posts] 4 years ago
Woolie boolies - feet were fine while my fingers froze
Strathlubnaig [113 posts] 4 years ago
Buffalo mitts - not pretty, but very, very effective. < £20
hanny152 [20 posts] 3 years ago
I bought Endura road overshoes this season and there are the best winter overshoes I have bought for cold weather rides: http://www.endura.co.uk/Product.aspx?dept_id=107&prod_id=14
