Hello,
How warm is actually the Rapha classic Jersey with Arm warmer? I mean I will be using a baselayer and will be riding by the sea between 8-20 celsious. Will it be warm enough under these temperatures taking into consideration that there is a wind and moisture, since i will be by the sea?
Is the longsleeve jersey a better option ?
2 comments
notfastenough [3728 posts] 6 years ago
I think that will probably be fine. You might find you want a windproof gilet, but other than that, I'd say go for it.
monty dog [464 posts] 6 years ago
Depends on whether you run 'hot' or 'cold' - you'd certainly need a baselayer when it gets towards 10 degrees and probably a gilet to keep some of the wind and moisture off.
