Increase leg speed (max cadence)
by JCornford on December 19, 2011 - 17:36
I'd like to increase my maximum leg speed, I have a road bike and a set of rollers, any suggestions?
I thought a spinning class would be a good idea, I went to my gym and said I wanted to increase my maximum leg speed and that I currently spin out at 180-185 rpm on my bmx and they said they couldn't help as they don't go up that high, do you guys have any suggestions?
180 rpm? I'd like to see that. Pros only spin in the low hundreds (ish). I average 70-75 on a good day (and 15-20 uphill!).
Pete
PeteH's picture
posted by PeteH [159 posts] 19th December 2011 - 18:13
I love doing Rollapaluza and spinning at silly speeds.
Spinning actually can be a great way to increase speed. The bikes should be flywheel, so you can be smooth, not clunky. Just don't stop suddenly! I practice by doing all-out spin sprints for 20-30 seconds, reaching 225+.
Otherwise, rollers can be useful, or just setting a low gear on the road bike, though far harder, as its likely you'll not have a rounded stroke, so you'll start clunking at weak points.
Technique is a big part though. Keep the body still, locked with your core, and just concentrate on keeping the stroke smooth, don't smash at it.
www.vulpine.cc
@aslongasicycle
@vulpinecc
aslongasicycle's picture
posted by aslongasicycle [28 posts] 19th December 2011 - 18:11
get a fixed gear with a low 'gear', say 63, or lower and ride down some big hills..
Fringe's picture
posted by Fringe [973 posts] 19th December 2011 - 19:36
225? Jeez...I'm impressed, I can't imagine that fast
Pete
PeteH's picture
posted by PeteH [159 posts] 19th December 2011 - 21:55
180-225? Hmmmm fine for a short stint but a thats not spinning in my opinion, thats just an interval you add to your spinning
For instance, i've just come back from the local gym, first time i've been there is 7 years, i just fancied a swim and a couple of mates were going
Jumped on one of their bikes, did interval's for an hour, highest rpm i got was 147 and my average over the hour was 88, quite happy with that, but was glad to hit the pool
Gkam84's picture
posted by Gkam84 [3278 posts] 19th December 2011 - 23:15
Fixed gears, shorter cranks and a turbo trainer or rollers will see me good for 240rpm plus - it starts getting a bit blurry after that! It's quite tricky to set up many spin bikes like a road bike too - Q-factor if often way too big and the big squishy saddle just causes you to bounce more IME.
Make mine an Italian with Campagnolo on the side
posted by monty dog [165 posts] 20th December 2011 - 9:47
90 rpm cruising then 110 for short blasts.
180+ is pretty dam good for sprints. But that's 3 revolutions per second. Are you going for
Endurance or sprints?
I like my bike but it needs a hidden 25cc motor Smile
Fish_n_Chips's picture
posted by Fish_n_Chips [325 posts] 20th December 2011 - 9:59
I'm going for standing up out of saddle full out sprints!
posted by JCornford [19 posts] 20th December 2011 - 10:34
Go for it!
Just remember to strengthen your joints and
allow good recovery before you go flat out.
I think most of us could do it before going
pop! Last thing you need is an injury.
Do plenty of research & understand it.
posted by Fish_n_Chips [325 posts] 20th December 2011 - 11:02
Doing RPMs over 180 requires a small gear. Its technique more than strength, although its the fast-twitch sprinters that have the best rollapaluza times. But a smooth controlled whippet can beat a big guy who smashes around. Its all anaerobic, so nothing endurance. thats essentially impossible at those speeds. You don't even need to breath....The oxygen debt afterwards is mental though.
But no-one should be having an average cadence below 80rpm, even 90. Its not good for you and not efficient. Most pros will spin closer to 100. Canc spins at 110 in TTs. That is not really spin training per se, though I guess it is if you're doing 70rpm!
Its all about pulling and pushing across the whole stroke. An easy way is to image you want to pedal in 'squares', push forward to 3pm, down to 6pm, back to 9pm, up to Noon on your cranks. That will get you there.
Also, force yourself to go 2 gears below what you would normally. Of course, you need a great position on the bike, and nice flat tracking of knees (no bobbling out).
Regards sprinting at high revs, don't try sprinting out the saddle at 225rpm, you'll kill yourself! You need to be seated.
Check out these links:
Its all about technique, concentration and stability. No mashing!
http://www.youtube.com/watch?v=sVbwngNoHm0
http://www.youtube.com/watch?v=Jgyq8Zkp10Y
www.vulpine.cc
@aslongasicycle
@vulpinecc
posted by aslongasicycle [28 posts] 20th December 2011 - 21:23
Thought I was watching my washing machine on spin cycle mode!
Brilliant!
(Will start to cruise at 100 rpm now)
posted by Fish_n_Chips [325 posts] 21st December 2011 - 17:40
Agree - don't try high speed cadence drills out the saddle - one slip and it'll be painful because there's still a lot of energy being generated at these leg speeds. Whilst high-speed drills aren't really representative of racing conditions, I find they're really good maximum threshold efforts - I can manage more of these than I can 'grinding them out' - the whole trick is to keep it smooth rather than stomping the pedals.
posted by monty dog [165 posts] 21st December 2011 - 19:01
Calendar
