Single speed commuter with mudguards & panniers
by onandon on November 17, 2011 - 14:13
Can anyone recommend a good single speed frame which I could run with mudguards and a light weight rack. Ideally just the frameset.
I can see a Ridgeback Solo reviewed here but I can't seem to buy one.
I keep looking at touring/audax frames but can't find one I can run as ss.
I'm fed up with getting soaked, I know, I'm soft!!!!
On One Pompetamine frame?
Not light, but cheapish and SS-able (but you'll need a 135mm spaced wheel and disc brakes).
Pompino would probably work too if you prefer cantis (in particular the newest version has more room, so should fit reasonable sized tyres and guards).
posted by pixelmix [18 posts] 17th November 2011 - 14:47
Got there first- just what I was about to say! But while you were typing I was grabbing a link- to the pompino cos I'm a cheapskate http://www.on-one.co.uk/i/q/FROOP/on_one_pompino_frame
Patrick.
posted by Littlehuan [36 posts] 17th November 2011 - 14:45
dave_atkinson's picture
posted by dave_atkinson [4766 posts] 17th November 2011 - 15:13
Tokyo Fixed do Dream Machine frame and fork for £450: http://road.cc/content/news/47184-new-house-frames-tokyo-fixed-one-youd-...
posted by nick_rearden [842 posts] 17th November 2011 - 15:26
Bear in mind that the Pompetamine has rear facing track ends - a pain in the bum if you want proper mudguards.
The Singular Peregrine (iirc) has an eccentric BB, a much better solution.
Rob Simmonds's picture
posted by Rob Simmonds [150 posts] 17th November 2011 - 15:31
the Condor Tempo is a single speed version of their Fratello, or Salsa do the Casseroll that you can run as a single speed or geared, both take proper mudguards.
Fringe's picture
posted by Fringe [973 posts] 17th November 2011 - 15:48
Trek's district single speeds have a good system for mounting mudguards. The eyelets move with the wheel when you tension the chain.
I have a Trek 2nd District with SKS Chromoplastic mudguards (don't have a rack yet) it works well.
Pru's picture
posted by Pru [5 posts] 22nd November 2011 - 14:40
Why buy new? Plenty of perfectly good frames out there crying out to be put back into regular use...
Riding an OLMO.... Which is nice!!!!
Gepin's picture
posted by Gepin [46 posts] 22nd November 2011 - 17:01
Why buy new? I'm riding an old carbolite Pug which is too big and it took 3 months to find that. Would love something old but where do I look? ebay? Any advice welcome man.
posted by onandon [4 posts] 22nd November 2011 - 18:42
posted by onandon [4 posts] 22nd November 2011 - 18:44
E-Bay/Retrobike/RoadCC Classifieds/Freecycle. Bound to be a kind soul on here with a frame your size kicking about doing nowt that they are willing to sell, stick up a wanted post.
Gepin's picture
posted by Gepin [46 posts] 23rd November 2011 - 11:39
Will give them a try...and thanks for the other advice guys, some new frames I've not seen before there.
Freecycle have really strong views about not allowing "Wanted" ads for bikes. I got the Pug from Freecycle and you'd have thought it was made of gold!!!
posted by onandon [4 posts] 23rd November 2011 - 17:12
our local freecycle group carries them regularly enough... Plain Face
you could try a local bike jumble too if you have one?
posted by dave_atkinson [4766 posts] 23rd November 2011 - 17:29
I've bought a few 70s "racers" from eBay for £50-ish, passed on the parts I didnt want to keep, and then enjoyed spending three times over on single speed bits, bars, stems, bags, bells, Brooks etc.
try singlespeedcomponents, freshtripe, tokyofixed & velosolo websites for supplies & inspiration.
posted by hirsthirst [7 posts] 23rd November 2011 - 23:03
there is no hassle putting full permanent mudguards on the On One pompino
posted by bfslxo [14 posts] 24th November 2011 - 11:27
Surly Cross Check. Can be built with or without gears.
posted by Pentti [3 posts] 24th November 2011 - 14:15
Out of interest, how did you do it?
posted by Rob Simmonds [150 posts] 24th November 2011 - 15:37
Hi Rob,
in fairness it was not myself that done this it is a colleague of mine who uses it for commuting over 38 miles a day - got this info of him
Yea, pompino.
As far as mudguards go, it is cavernous!
I have full guards and 28c tires on underneath.
SKS Bluemel olpympic guards.
http://www.chainreactioncycles.com/Models.aspx?ModelID=33154
It has 120mm track spacing on the back which makes for a nicer wheel, but limits your hub choices.
let me know if u needed a bit of guidance on it I'm sure I could put u in touch with him
posted by bfslxo [14 posts] 25th November 2011 - 16:29
bfslxo wrote:
Hi Rob,
Yea, pompino.
Um, thanks, but that doesn't actually address the problem, which is how do you get the wheel out? Full length guards will get in the way unless you have some cunning bodgearound.
posted by Rob Simmonds [150 posts] 25th November 2011 - 20:46
A little late on this, but in case it helps someone. The bodge is to fit SKS secu clips to the rear mudguard stays instead (or as well, if you buy some extras - St John Street have them for a princely £1.01). Then you just pop out the stay to change the wheel.
Angus Rivers
posted by angusrivers [2 posts] 23rd February 2012 - 10:50
Calendar
