Brakes not releasing
by charliealmond on November 1, 2011 - 21:11
So I took my wheels off my new bike yesterday for the first time since buying it - put them back on today and the brake calipers won't release properly now! Squeeze the brakes and they just stay on the rim. Brakes are 105 levers with Tektro dual pivot R540.
Dunno what I've done! Not like I've not taken wheels off 100's of times before...really strange.
Any help appreciated.
Cable snagging somewhere maybe?
if you disconnect the cable and the brakes spring open nicely then you know the brakes are okay and the problem lies elsewhere.
TheHatter's picture
posted by TheHatter [529 posts] 1st November 2011 - 21:27
Check the above, but at this time of year, calipers have a habit of seizing up, especially the rear.
Is it both wheels or just one?
Online cycle coaching and cycling equipment shop for all of your Racing, Sportive and Fitness needs.
Koolstof Coaching www.koolstofcoaching.com
Koolstof Cycle Components www.koolstof.co.uk
Koolstof's picture
posted by Koolstof [5 posts] 2nd November 2011 - 11:17
if it's the pivots, use some penetrating oil to free them up. once you're sure they're running smoothly, i find that forcing some grease into the pivots helps to protect against it happening again. you don't have to take the brakes apart, just squeeze some grease on to the outside of the pivot and push it into the gaps with your fingers or a toothbrush.
dave_atkinson's picture
posted by dave_atkinson [4766 posts] 2nd November 2011 - 11:31
Thanks for the suggestions guys. All the cables are fine, clear and snag free. It's both brakes and happened straight after I took the wheels off on Monday to put the bike in the car. The springs are still in the correct places.
I'll try and re-oil them all to get them running smoothly, but I've only had it 3 months!
charliealmond's picture
posted by charliealmond [3 posts] 2nd November 2011 - 13:36
silly question, but have you checked the... what's it called... the tension release levers that let you have more room to get your wheels off easir? You know, where the cable anchor pouint is? If anybody could explain what Im talking about, that might be the problem...
"I can't believe I ate the whole thing..."
Cooks's picture
posted by Cooks [253 posts] 2nd November 2011 - 23:58
Check that the cable outer hasn't popped out of the calliper adjuster and is sitting on the edge.
Might just need reseating in the calliper adjuster.
posted by TheRealYeti [6 posts] 3rd November 2011 - 17:07
Yes...Cooks' idea looks favourite...maybe you took delivery of the bike with the brakes'Q/R levers UP, ie in the release position, so that when you put the wheels back and snapped the brakes tight, they're too tight. Otherwise you've just contracted BTR syndrome. (Brakes too tight, caused by assembly mechanics not paying attention to the job in hand). So release the nut holding the cable and then tension it yourself, as in Self-help. All t'best.
P.R.
PhilRuss
posted by PhilRuss [41 posts] 17th November 2011 - 18:21
Calendar
