Hello everyone  1
I'm quite new to cycling so you'll have to forgive me..
I was riding home today when I heard a loud clunk from my rear wheel.. closer inspection revealed that one of my spokes had dropped out.
I have no idea if this is a serious problem and I'd rather not pay for a service my bike might not need..
I'd really like to fix this myself if I can but I have no idea how to do this or if its even advisable for me to try.
Any advice would be really appreciated,
Thanks
2 comments
dave atkinson [6281 posts] 7 years ago
it's not too hard to replace a spoke, but it's made harder if it's a rear drive side one (it usually is as they're tighter) because you'll most likely need to take off the cassette to seat a new spoke, depending on what kind of wheel you've got. a bike shop won't charge much to do it and you will need some specialist tools, but if you choose to go it alone then basically it's like this:
first you'll need a new spoke the same length. if you've got the one that fell out you can measure that, if not there's loads of online calculators (http://www.ctc.org.uk/DesktopDefault.aspx?TabID=3524) or your local bike shop can help.
take off the rear wheel, remove the tyre, tube and rim tape, and cassette too if it's a drive side spoke. feed the spoke through the rim, make sure it goes through the rim and under and over the other spokes the same way as the rest of the spokes that go in the same direction.
feed the spoke nipple into the hole in the rim, and screw it onto the spoke with a small screwdriver. tighten it with a spoke key until it's fairly tight. You'll need to true the wheel, you can use the brake blocks as a guide and tighten or loosen the spokes to pull the rim in the direction you need. It's not a dark art but it does take practice.
my suggestion: take it into the shop for them to do it and ask if you can watch. then you'll have a better idea for next time!
bbrrww [13 posts] 7 years ago
Thanks for all your help  4
I think I'll take the bike to the shop tomorrow like you suggested, asking to watch is a great idea thanks for that.
Cheers
